Drag Racing Tech
View Poll Results: Best option for street/strip
Lightweight (hawker) in stock location
29
59.18%
Relocate the battery to the trunk
20
40.82%
Voters: 49. You may not vote on this poll
Lightweight vs. Battery relocation
Old Sep 28, 2006 | 07:56 PM
SiL3NtXWS6's Avatar
So 10.99 or quicker pretty much requires you to put it in the rear so you can have a shut off switch?
Old Sep 28, 2006 | 09:19 PM
calongo_SS's Avatar
I think that is NHRA only, not IHRA
Old Sep 28, 2006 | 09:40 PM
SScam68's Avatar
hold on a sec, this is the first I ever read/hear of this.
If i'm running sub 11's I have to put it in the back anyways?
I would do the lightweight in the front. I just yanked my relocated battery and bought the Odyssey.
14lbs in cable alone. With that being said, cable, box and battery were about 50lbs in the back. I noticed no difference in moving the stocker back up to the front in the 60'. Not only that I dropped 26lbs from the box, wiring and hardware and another 20 from running the Odyssey battery up front.
For a street/strip car it just makes more sense.
Old Sep 29, 2006 | 07:44 AM
stealth71's Avatar
Are you guys getting the normal PC680 or one of the other versions PC680MJ, PC680MJT?
Old Sep 29, 2006 | 01:52 PM
94z28L's Avatar
you dont have to however you do need a master disconnect switch and with the battery in the rear it makes it easier to do
Old Sep 29, 2006 | 11:40 PM
Magnet's Avatar
where can you find the PC680??
Old Sep 30, 2006 | 03:56 AM
TXCAMSS's Avatar
"All Motor 9 Second club member"
www.gotbatteries.com sells them. It's a great mod IMO. I haven't tried mine with the new 408, but it never missed a beat with the H/C set up and we daily drive the car. They just don't have much reserve for radios, fans etc. I may sell mine since I'm not using it. I'm afraid it might be a little tough spinning the stroker over.
Old Sep 30, 2006 | 05:00 AM
JL ws-6's Avatar
Race your car!
my 402 that's over 12 to 1 fires right up with my pc680. I keep a battery tender on it when it's sitting in the garage for safety, but I don't know if it's needed. I definately don't roll up any windows, no radio, no lights, none of that unless the motor is running, I figure as long as I keep that up I don't forsee any problems with it.
Old Sep 30, 2006 | 08:31 PM
02SOMWS6's Avatar
any body got pics of the hawker mounted? Do I need anything else as far as different ends or post to make the stock battery wires work? I want to swap out my stock battery ,I only have the stock wires for the battery so if you guys could think of anything I would need for the swap that would be great.Thanks in advance
Old Sep 30, 2006 | 10:40 PM
JL ws-6's Avatar
Race your car!
I don't have a pic, but the only thign I got to do the swap was a set of the hawker battery terminals... I layed the battery on it's side, and used a 1 inch wide pieve of alum to make a strap to hold it in place. I used the stock battery hold down bolt, and then bent the lum to sit on top of the battery, in one of the battery case grooves, then bent it another 90degrees, and attached it to the radiator support with one good sized sheet metal screw. I tried to move the battery as hard as I can and it's in there tight, so it should pass tech, and I'm certainly not worried about it shifting around on me.
Old Sep 30, 2006 | 10:54 PM
chy20k1's Avatar
anyone daily drive the pc680 in cold weather? i live in NY and it can get quite cold here in the winter.
Old Sep 30, 2006 | 11:21 PM
  #32
ls1408cp's Avatar
this is the only pic I have. I mounted it on the frame rail because my dedicated fuel system is where the battery tray use to be.
Old Oct 1, 2006 | 12:04 AM
  #33
G&HRacing's Avatar
8 second club
10.99 is not correct, Any car running 9.99 or quicker (6.39 1/8) or any car fastest than 135 MPH must have a Master Cut Off Switch. And of course any car with the battery in the back must have one.
Old Oct 1, 2006 | 03:47 PM
  #34
Magnet's Avatar
so would this be a good ro bad idea for a pure street car with stock electronis aka radio, fans etc..? its never gonna see cold weather (florida)
Old Oct 1, 2006 | 07:32 PM
  #35
JL ws-6's Avatar
Race your car!
That's what I thought... good to finally get that cleared up.
Old Oct 2, 2006 | 02:38 AM
  #36
Magnet's Avatar
to the top.... good for a pure street car or not???
Old Oct 2, 2006 | 04:18 AM
  #37
calongo_SS's Avatar
SUX2BU daily drives his I believe, so I don't see a problem with it. I'm going to get one soon for my weekend car.
Old Oct 4, 2006 | 04:26 PM
  #38
foggedz's Avatar
This is exactly where I have mine mounted. Works great, never had problems with starting the car.
Old Oct 4, 2006 | 07:54 PM
  #39
TXCAMSS's Avatar
I used to swap mine out for racing purposes when I had H/C and then I forgot swapping it once and we drove it for about 6 months daily and never had any indication it was anything less than the big stock battery.
I got worried about the Stroker being too much so I went with a Braille all season battery. It's the same size as the Hawker, but with a few more cold cranking amps. I'll be daily driving it as well. I'm not pulling it out until it lets me down, which isn't likely.
Old Oct 7, 2006 | 10:37 AM
  #40
kp's Avatar
kp
FWIW, switching from a PC680 up front to a red top in the rear I added 55lbs to the car. Two sets of big cables, battery, cutoff switch and box/hardware adds up. No way a PC680 will keep up in the back if you have to start the car a lot at the track and you are running big fuel pump/EWP etc. But I never had any problem from the PC680 up front even bracket racing the car, but I didnt have the EWP and leave it run to cool the car off.
