Comp. Engineering drag shocks
The instructions are printed on the box. Adjustment is fairly straight forward.
what is the differences in the settings?
is the higher or lower number stiffer?
is the first or second number compression?
Lets say you are running 50/50 and the track prep is bad and you needed to hook a little better. Would you keep it as is or go with another setting? which setting?
would these settings be correct:
Traction/ET/Track Condition
70/30 best/slowest/worst
60/40 good/good/good
50/50 worst/Fastest/best
According to Summit however, it states:
I got home to find my new shocks in a plain brown box with summit's part number, not a CE box, and there are absolutly no instructions anywhere...
The shock are the CE and correct part number with C2700 in the side so I guess to save money they send them to summit in plain boxes...
So on the shock there are 3 settings XF, F, and R... What are these settings? Can I assume R is Race?
Thanks guys...
Here ya go. BTW, this is for rear shocks. Fronts are different.
R = 50/50
F = 40/60
XF=30/70
To adjust:
Fully comress shock.
Note: When adjusting shock, keep in the upright position.
With shock still fully compressed, rotate clockwise for several revolutions after "clicks" are heard. This action full engages the adjustment mechanism.
Rotate notch indicator to desired setting.
From the box: A 30/70 setting allows the rear body to compress with minimal resistance for maximum weight transfer - the ideal setting for a slippery track. When track conditions are perfect, the 50/50 setting will not overload the rear wheels preventing wheel hop.
Hope this helps!
Thanks guys...
Thats where mine are coming from. I was going to buy mine from byunspeed (they are the same price as summit) but I had to send something back and exhange it so I just got them from summit because shipping was not extra because they were already sending something to me.
I was going to go with a 2 way adjustable shock but with all the recent mods my mod buget is getting tighter so I figured these had to be better than the stock shocks that have been on the car for 9 years. These should hold me over for a while I hope.
If someone has instructions please post them.
Edit: I was a little slow typing this, got distracted. thanks for posting instructions.
I bought a set from speed inc and they were a bad set, they wouldn't click, speed inc took care of it and sent me a new pair.
Don't know if im just being skeptical because of the bad set, but when adjusting they click all the way around and in real lightly were the settings are at.
I just got them in today and drove it around the block feels ok, are they suppose to do anything different, or how can I tell they're working correctly?
https://ls1tech.com/forums/drag-racing-results/827598-video-new-pb-9-51-142-nitrous-street-car.html
The car wont drive any different then regular shocks really, I use the 'middle' position, 40/60 or 60/40 or whatever it is..
