Drag Racing Tech
Comp. Engineering drag shocks
Old Dec 11, 2007 | 06:44 PM
  #61
98Z28CobraKiller's Avatar
Restricted User
Originally Posted by kp
The CE shocks are still working fine for me, 8.90s (1.27 60') isnt bad for a set of cheap rear shocks, stock rear springs and SA Strange front shocks.
The car wont drive any different then regular shocks really, I use the 'middle' position, 40/60 or 60/40 or whatever it is..
+1....
Old Dec 14, 2007 | 04:38 AM
  #62
BLOWN SS/T's Avatar
I can only dream right now of hooking up like your car in that video. Bad *** ride.
Thanks everyone, I tried launching my car a few times and all I got was a smoke show with the almost bald 18" 555R's. It's time for some MT's, I got a spare 10 bolt if anything.lol
Old Dec 14, 2007 | 11:22 PM
  #63
djsanchez2's Avatar
Good to hear you fellas are having success with these shocks. Just nabbed a NIB set for $40 shipped.
What setting would you reccomend for a DD. Keep in mind, i don't mind pulling them to change the settings if need be. Also I will be using them, on the street, no track round here. So, also what would work good on the street, or is it really just T&E?
I'll also be going back to the stock springs with these.
Old Dec 14, 2007 | 11:32 PM
  #64
Hrod382's Avatar
What's everyone doing up front?
I had CE's but they were just too inconsistant, put on some cheapy no names and lost height and about .01 but gained a good deal in consistancy. They junked out on me at the end of last year, car had a wicked wobble to it after the front end sat down.
Are the DA coil overs worth it? I'm thinking about AFCO's or QA1's on my '67, it's about to get a 548 (about 200 more horses) in it which should put me down in the 5.70's or 5.60's. We have scales so I can dial it in... That's the main reason I'm thinking it might be worth the cost.
Old Dec 14, 2007 | 11:54 PM
  #65
djsanchez2's Avatar
Alot of the guys are going QA1 w/ either 300 or 275 springs up front. I'm going to follow suit when i get my 9"
Old Dec 15, 2007 | 12:23 AM
  #66
RAGENZ28's Avatar
I have 275's up front 150's in the rear.
Old Dec 15, 2007 | 02:04 AM
  #67
35th SS's Avatar
exactly what Im running on both cars.
Old Feb 2, 2008 | 09:53 PM
  #68
daniel6718's Avatar
jus wondering if it is bad if mine dont click...one does but when it clicks it gets stuck and wont move?
Old Feb 3, 2008 | 04:48 PM
  #69
djsanchez2's Avatar
That's kinda wierd. Did you try resetting them? (pump them 8-10 times then on last one, keep the piston in, and twist a few times til the lil mechanism engages) Then you should be set to go. If not call up the company you got em from and let em know.
Old Feb 3, 2008 | 05:19 PM
  #70
BAKED's Avatar
1.37 60' on radials with CE rear shocks, air bag, stock front and rear springs and stock front struts.
I do have BMR SFC's, LCA's, PHB, and a bigger sway bar.
Old Feb 3, 2008 | 05:26 PM
  #71
djsanchez2's Avatar
What tire and launch rpm? that's damned good!
Old Feb 3, 2008 | 05:34 PM
  #72
daniel6718's Avatar
well i bought them used....and i tried went in and out like 8 times then tried to turn it but didnt work...
its pretty easy to pull out but hard to compress so i think its on 70/30? and stuck? any way to fix it? i dont see how it broke inside....doesnt leak any oil or anything
Old Feb 3, 2008 | 06:02 PM
  #73
BLOWN SS/T's Avatar
I bought a new set from speed inc, and they would do the same thing. I didn't think they were right so speed inc said to call comp and comp said they were defected. I sent them back to Speed Inc and they shipped out a new set. And the new set clicked, somone on here said that for his monte carlo they wouldn't click but on his fbody they would.
More than likely they are bad, IMO.
Old Feb 3, 2008 | 10:48 PM
  #74
BOLO's Avatar
Originally Posted by Taubr Unit
I know a lot of people use eaither stock or QA1's. I know the 98+ have better rear shocks compared to my '94. How do Comp. Engineering shocks compare to my stock ones. I dont wanna dump $300 on QA1's for the rear but $80 for Comp. Eng. are do-able. Worth the money or not much better then stockers. I already got everything else (ta, panhard bar, sway bar, lca's springs) so a set of shocks will finish it all off. What u guys think.
Works here for me. See video below.
Old Feb 4, 2008 | 02:18 AM
  #75
daniel6718's Avatar
fu** i bought these used and the guy said even though they dont click they still swap to each setting...i tried it and it feels the same..easy to pull the rod out and hard to go in...mayb comp will hook me up with another or this guy will make things right
Old Feb 5, 2008 | 07:53 PM
  #76
daniel6718's Avatar
i tried to reset them and didnt work
Old Feb 5, 2008 | 08:51 PM
  #77
djsanchez2's Avatar
Then they are prob. screwed up or defective. Most likely why they were sold in the first place to be honest. (or he didn't know)
I say you contact the seller and see if he'll right the wrong for you.
Old Feb 7, 2008 | 04:15 PM
  #78
RAGENZ28's Avatar
I have C/E shocks on my rear and have used them since 1998 and they work great =) Buy then new and stop trying to save 20 bucks on a used set lol.
Old Feb 11, 2008 | 05:02 PM
  #79
bowtierodder's Avatar
i just bought a set of these but they dont extend on their own like a normal shock, you have to pull them out. is this normal?
Old Feb 11, 2008 | 05:22 PM
  #80
daniel6718's Avatar
yea thats how both of mine are...id like an answer on that also
