guys I need some help
Yes there are no opens in the harness. I really hope they are right about my grounds,but I'm thinking its not gonna work. I'll see here in a few days.
My buddy is putting the front mount distributor in his ls1 as we speak. It has became kind of an ordeal in itself. On top of buying the front mount cover and cam driven gear, you have to obviously buy the Ford Distributor and a box. On top of that you end up having to space out the waterpump like 3 inches which might cause a problem in an fbody. Then, you have to pin the crank as well which means pulling the motor. Kind of a cool setup, just thought I'd let you know that you'll have to pull the motor so if it ends up with that you know what you're getting into.
Doug
Just making sure, that has got a lot of people over the years..
I'm looking at the instructions and there is really nothing to it, I would double check the cam/crank sensor wires and make sure the pin out is correct and they are getting 12v while cranking. Sometimes the A-B-Cs gets crossed up and if you hook up the cam or crank sensor wrong they are instantly fried..
I think KP hit the nail on the head ! The fuel pump might not be getting power during start mode also.
I don't know if you are going through the factory ecm or how it is wired. We had the factory anti theft system removed from the program and after several battery disconnects the car would not start unless we used the key with the chip in it.
Alan
The only thing I can think of is avoltage drop while cranking. I have no idea why it ran the factory pcm just like it is now.I wil say one thing this car never sounded so good. Screw efi this is the only way to go it sat there and idled at 1350 rpm and had the good ole exhaust squeak at idle this thing is gonna fly
I just wish I could get it to fire all the time
Maybe it worked with the computer because of the start timing or something beign differnent making starting easier?
have you tried/can you put a stock sized battery back in the front to see if that will solve it, or is there way to play with the start timing with that msd box... maybe it's something like that, or maybe the wire resistance going from the back to the front is the problem. Is there a dedicated ground wire from the battery to the MSD box? Try that possibly.. that might fix it too.
Thanks guys
Don't forget that's 6 ac volts factory recommends 4-6 ac volts. We'll see what happens here in a couple days.
You need a driver for that PINKS car
Not sure if you have the wires/lugs up in the front still, but I'd put a battery up there if you can just to try it... if that works then restring teh biggest damn wire to the back you can find.
Could the battery kill switch in the back be going.... that might bhave some resistance to it too if it's getting worn, could also be a problem.
If you can, take a multimeter and get a resistance reading from the positive battery terminal to the power wire up at the front, when everything is on it shouldn't be much at all
