what motor mounts, and what spark plugs for iron motor??
8 second mod
looking for info.
what plugs are you very high power NA ls cars running for plugs? call it a mid 9 seconf na car, what plugs?
also, i have run my stock motor mounts this hole time, if i go to iron block and high hp what motor mounts should i get?
i have older bmr k-memeber, and dont think i want to do motor plates just yet, dont think the class i will be racing alows them.
thanks
thanks
8 second mod
kp, im going to be around 15 -1 so i'll start with an 8
tosto, saw your pinks the other day finnally, sick, just sick!!!!! your car is just the nicest f-body i have ever seen!!!!! i put alot of work and pride into my car and it shows, after seeing your car, holly hell you did a great great job!!!!!!!!
also, for your starting issue, i wish i could help, all i can tell you is last year i had the same issue and it was my ls2 front cover. i had to swap the 2 wires, other then that everyone is telling you the same things i would. wish i could help.
and also, thanks for your info! whatpolly mounts are the best in your opinion?
8 second mod
Originally Posted by JL ws-6
brad I put the poly ones in my car and the motor doesn't move at all.
Not at the level you are looking to run...but if it's worth anything.
Why the iron block, was your old block NFG?
why the iron block. hmmm, i have new plans
