Open Trailers, what are you using hassle free?
#41
Before I bought a 24' enclosed, I had an H&H Speedloader MX. Had a full wood deck on it and the wood had a lifetime warranty. It was about $1700 new 6 years ago. I think they're a bit over $2k now. With my car being lowered it would scrape the nose barely, so I cut 4 pieces of 2x12 about 2' long and stacked 2 in front of each tire right at the start of the ramp. That gets the front wheels up 3" higher before they hit the trailer deck and you'll have plenty of room for the nose to clear.
http://www.hhtrailer.com/05SpeedLoaderMX.asp
Craig
Craig
#42
Originally Posted by Hawkn01
Yea, it's hard to get a good nights sleep knowing what "could happen" while they sit in the hotel parking lots over night
thats why I went with an enclosed trailer when I had the car
#45
I towed my 26' trailer with a 1500HD 6.0L/4L80 pickup to bowling green and back (220 miles each way) one time to try it and it was a no-go for me. Lot of big grades around here, if I lived 50 miles from the track and it was relatively flat I would do a gasser, way less hassle then a diesel. An 8.1/allison tows well though, if you can take the 7-8mpg. I ended up with a 2500HD dmax short bed crew cab, not a bad everyday cruiser and can pull a house..
#46
Originally Posted by TwoFast4Lv
I used both last season and the true Texas roll back was nicer for many reasons
First and formost the way the fenders came off no hassel to get in the car even after it was strapped down. Just pull the pins and lift them off. Next was the fact that the Texas roll back has deck lock pins on BOTH sides of the trailer. The TR felt more sable when braking
Just MHO after using bost
#47
Check out WWW.SURE-TRAC.com,18 ft all steel,complete trailer is POWDER COATED(NO RUST),4ft dove tail,5ft ramps,stake pockets with rub rail,car goes up and down with GOOD clearance!! 2350.00 plus tax. bought it from www.needatrailer.com,(R&P TRAILERS AND CARRIAGES),Seneca,illinois 815-357-3292.nicest open car trailer for the cost,looked at plenty of brand new ones that were rusting out from just sitting on the lot.
#48
Originally Posted by BradWS6
I used to tow my 28ft with my 05 HD2500 with the 6.0 motor, it did ok,struggled on hills. My HD2500 Duramax tows the 28ft like nothings behind it.
#49
Originally Posted by Elite_Hot_Rod
They are both the same design. Sloan designed the Tx roll back and they "borrowed" his design.
Since then I have bought a 03 D/A CCSB and I am looking at 28ft trailers. I still may get the TX RB due to its easy use for Customer pick up and delivery
#50
Originally Posted by Luis Castellanos
Anyone here tows a bigger than 24' enclosed with a GAS vehicle?
#51
Race your car!
Out of curiosity, what does that d-max pickup get for mileage around town and on the highway with and without the trailer? I'm gonna tade my rcsb 1500 ram in for a 3/4 ton 2wd crew cab job hopefully in about a year to a year and a half... gas mileage with the diesel is something I can't get a real strait answer on.
#52
Our 2500 pulls our '30 great, just that gas mileage obviously is terrible.
#53
I just looked at trailers today, paying close attention to the height after reading you post. I found a local company LOE Trailers that designed theirs for this reason. They have a full deck and and open center which the decking is below the frame thus lowering the height. The full deck one also was redesigned with the Dove tail lengtened to 4 feet with a lower angle. I think that is the one i want. I think they may be on the web.
#54
Originally Posted by 1QuickT-A
If you get a 3/4 ton with a GAS burner and a MANUAL trans you can pull plenty of weight.. We have an older model crew cab chevy dually (84 model i think) with a 454 and a 5spd with granny and 4.10 gears. We pull a 32ft tri-axle enclosed with a ProMod, 4wheeler, tools, bottles, etc etc and you can pull hills in 5th gear most of the time..
I am interested in a 28' enclosed, but I don't want to take any chances with the truck.. going diesel is not an option just yet...
#56
But honestly, while its 'cool' to have a diesel they require more maintenance, PITA to find fuel sometimes and you are paying a huge premium to get a diesel to begin with. If I didnt live in the mountains I would be using a gas truck. I used to tow a 42' enclosed with a 454 gas dually (manual trans) and thay did fine, except it got like 4-5mpg lol.
#57
My cummins (2004 Dodge 3500 6x6 6 speed) gets about 17 in town and around 20 freeway. Gets 15-17 trailering. When I had a programmer on it, it got even better mileage. The 2 piece driveshaft didn't like the extra power though. So, we took the programmer back off.
#60
Hemi Megacab here... I have been told it can pull 10,000lbs easy.. but I cant miss any gas station...
