What tire Pressure in Mickey ET Streets?
Iv heard different opinions from friends and people on what pressure to run at the track.Im running tonite and I thought about starting out at 28 and then going from there.Also heard on here tht u dont need to do a big burnout just alittle heat up for the Mickeys plan on doing that as well.Any suggestions??
Depends on how much power you're making. If you are stock, or a 12 sec. machine, 20'ish should work. If your an 11 sec. or less, you need less pressure. I'm assuming, since you have to ask, that you will be running 13's or 12's. If that's the case, start at 20 psi and go down.
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
![Try Search](https://ls1tech.com/forums/images/smilies/trysearch.gif)
https://ls1tech.com/forums/drag-racing-tech/689401-about-mt-drag-radials-track.html
Good luck getting her hooked up!
Derek
