Drag Racing Tech
Ratcheted tie-down to keep engine from torquing?
Old Apr 30, 2007 | 10:31 AM
James Montigny's Avatar
Default Ratcheted tie-down to keep engine from torquing?
I've seen this on a few cars as of late.
It looks like it has bad idea written all over it.
People are wrapping nylon tie-downs (the kind you'd use to keep your ATV
from falling off the trailer) around their accessory brackets and tying them to
the K member to limit engine torquing on hard launches.
When I asked about it, one guy looked at me like I was somehow in the dark
about this magic trick and that I was crazy for suggesting stiffer motor
mounts or plates.
Thoughts? (and no, you won't be seeing this on my car anytime soon)
Old Apr 30, 2007 | 12:39 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
On the driver's side? Yup I did this 7 yrs ago, worked fine.
Old Apr 30, 2007 | 03:26 PM
LC's Avatar
LC
with tie-downs?
Old Apr 30, 2007 | 04:13 PM
LS1Tech Co-Founder
Ran a strap arounda bracket, and bolted one end to the k-member. Worked for a few years. The fancier and better way is to run a chain from the body to the engine and bolt the chain to the engine.
Old Apr 30, 2007 | 04:49 PM
jldak318's Avatar
a good friend of mine has the chain on his s-10. it works really well.
Old Apr 30, 2007 | 06:00 PM
Wow ....
Old Apr 30, 2007 | 06:16 PM
KCFormula's Avatar
I've used rachet straps on cars. A good thing when the motor mounts aren't designed for high hp or are so loose the motor leans over against the shock tower.
Old May 1, 2007 | 08:35 PM
AutoRoc's Avatar
Look at it like subframe connectors. If you were serious, you'd get a full cage buit your not THAT serious about chassis stiffness. Strap and chain guys aren't ready for engine plates and solid mounts...
I'll probably do a cable type when I do the cable type suspension limiters...it probably does help quite a bit from having weight tranfer over to the passenger side if your car makes a lot of power.
Old May 1, 2007 | 10:26 PM
DrkPhx's Avatar
It's a trick the Turbo Buick guys used. I ran a 1" ratchet tie down from the alternator bracket to the frame.
Old May 1, 2007 | 10:27 PM
JRracing's Avatar
Why not just buy some sphoon solid motor mounts. They are cheap and easy to install.
I have them and it does not vibrate the car hardly at all.
Old May 1, 2007 | 10:45 PM
TJ's Avatar
TJ
solid mounts is the answer, but some folks complain about vibration.
if you need to strap your motor, you got vibration anyway.
i say mounts, but please dont run a tie down.
AT LEAST use some type of nice turnbuckle.
make it look like it belongs there.
they even have stainless ones at the boat shop, or some nice forged ones with gold plating at the tractor/lawn shop in your area.
good luck.
Old May 2, 2007 | 03:30 AM
revtime's Avatar
yeah this is an old school drag racers trick.
I did it on my Chevelle way back in the day.
I used a length of chain though not a tie down strap.
Old May 2, 2007 | 08:41 AM
LS1Tech Co-Founder
Well I'm sure poly motor mounts would work just as good or better, but back in 2000 they didn't exist, and the strap took 10 minutes. Stopped my Mac Y pipe from hitting the driver's side floorboard.
Old May 2, 2007 | 11:25 AM
EDS01SS's Avatar
Ok this question is a little bit off topic but since were talking about tie straps and chains for bracing on a motor another question popped into my mind.when Im launching my car and bringing the RPMs up the back end of my car will raise real high allowing me to only launch at like 2000 RPM without loosing a bunch of time during suspension movement. I have a 3500 stall and I believe I still have more in the car if I could launch at a higher rpm.Would strapping the body to the rearend to limit the suspension travel help me any or should I be looking at my torque arm adjustments or something else?
