Drag Racing Tech
launching stalled auto w/ stock suspension?
Old 05-09-2007 | 09:46 AM
Bryan @ Speed Inc.'s Avatar
Default launching stalled auto w/ stock suspension?
anyone here running a full weight, stalled auto car, on a drag radial WITH a stock torque arm, lca's, shocks/springs....etc. ????
what are your set-ups and 60' times???
thanks.
Old 05-09-2007 | 02:11 PM
anyone have any experience w/ this???
Old 05-09-2007 | 02:22 PM
gator's 99TA's Avatar
a good friend of mine had 100% OEM stock suspension, boltons, and a set of 26" et streets on stock TA wheels at stock weight going 11.20 on a 100 shot pulling 1.49 60' - he eventually bent his tq arm.
Old 05-09-2007 | 02:51 PM
wow... well i'll be using drag radials, and 60's probably in the low 1.6's.... and probably will be low 12's so hopefully i wont bend mine.
so hooking it can work...........? thanks for the reply hopefully i'll be able to hook it up.
Old 05-09-2007 | 02:55 PM
good converter, enough torque, and a good drag tire and you will hammer out of the hole.
Old 05-09-2007 | 03:04 PM
stock motor, 3600, bfg on stock rim, 3.23 gear
i'll remove my front swaybar, i might have to go to a m.t. drag radial.
Old 05-09-2007 | 03:20 PM
Matt D's Avatar
Retired Street Racer
You have seen how both of my LS1s moved on the MT drag radial. Why do you think I recommend them to all of the local guys? I will put a 275/50/15 against a 26x10x15 ET Drag any day. I always ran faster on the DR
Old 05-09-2007 | 09:41 PM
xpndbl3's Avatar
i run more consistantly on a 28x10.50 ET drag than a 275/60 drag radial any day of the week.
Old 05-09-2007 | 10:44 PM
camscam02's Avatar
i pull 1.48's with only a bigger rear sway bar and slicks! the best on drag radials was 1.55 on all stock suspension and bfg drag rdaials!
Old 05-10-2007 | 12:05 AM
F8L LT1 Z28's Avatar
I was getting 1.7, 60 foot times on my stock shocks/springs all I had was a 2800 stall. 255 DR
Old 05-10-2007 | 08:03 AM
WILWAXU's Avatar
IMO, you can't compare MT Drag Radials to any other DR. They are that much better.
Old 05-10-2007 | 09:16 AM
i'm just working with what i got here matt. i bought the car w/ 245/50/16 BFG drag radials.
i'm just trying to see if i have hope of hooking this thing w/ out poppin' for new tires.
Old 05-10-2007 | 09:29 AM
darrensls1's Avatar
3500 stall with 2.5 STR here. 3.23's, 100% stock suspension and the rest of my mods are in my sig. Tires are M/T street radials 255/50/16 on the stock rims.
My 60's range from 1.69 to 1.80 with 1.71-1.74 being about average. I run 19-21 psi in the M/T's, do a five second burnout and I almost always dead hook. My best results are from reving between 2000 and 2500 rpm's and flooring it. But I have also had good success just flashing off idle. But I only do this towards the end of the night when my gas tank and air temps get low enough that I stopped dead hooking.
Old 05-10-2007 | 10:42 AM
thanks for the info guys!
Old 05-10-2007 | 04:48 PM
jakesz28's Avatar
I went 1.68 60' with stock parts, 2800 stall, drag radials
Old 05-10-2007 | 07:53 PM
brandonppr's Avatar
I went 1.47 60ft with stock:
TA
rear swaybar
rear shocks
rear panhard
rear shocks
aftermarket:
LCA
12bolt spool 3.73
front shocks
front springs
!frnt swaybar
The TA was ok untill I started getting into the 1.4x 60fts
Old 05-11-2007 | 10:33 AM
^^^ sweet!
Old 05-11-2007 | 11:22 AM
brandonppr's Avatar
I just noticed you said full weight. Mine was not full weight though.
Old 01-27-2008 | 08:16 PM
allbaugh_04's Avatar
which bfgs? what size?
Old 01-27-2008 | 08:27 PM
SilverGhost's Avatar
Motorboater
we broke MULTIPLE stock torque arms with the setup you are describing back in the day. bolt on and cam only cars with converter and a tire and nothing else.
