Drag Racing Tech
3" true duals VS Magnaflow mufflers off the collectors
Old 09-26-2007 | 09:56 PM
Matt D's Avatar
Retired Street Racer
Here is a link to a video of mine from back in June: http://video.ls1tech.com/video/83106...59018a487d.htm
TS6: I don't drive mine on the street unless it is from my house to the track (less than 2 miles) or to the shop (3 miles away). I had my guy turn them out instead of straight down for the sound and fume factor. I think turning them in at the same angle would have the same effect.
Old 09-26-2007 | 10:26 PM
dug's Avatar
dug
Im diggin the sound
Old 09-30-2007 | 04:33 PM
WMSuperSport's Avatar
You guys convinced me to run this setup, only I'm gonna try dynomax bullets first. If it's too much I might go to a bigger muffler like the Magnaflow. I loved the way my Magnaflow catback sounded so I can just imagine how this setup would be.
Plus good weight savings.
Wes
Old 10-02-2007 | 06:25 AM
wolfy's Avatar
Originally Posted by TS6
One note, I notice all you guys turn your turn downs out, try turning them in. For one, its supposed to help with the noise, for two, it will help keep the fumes away from the window, and three, it keeps your car from kicking dust to the outside, which is super annoying at car shows and stuff.
ive always wondered why everyone seems to turn them out as well..
we've always turned them in for the same reasons you mentioned, but more-so because it keeps the water in between the tires more, instead of spraying it towards the tires in the event that we push a head gasket...
Old 10-03-2007 | 11:43 PM
PRAY HRD's Avatar
hey Matt...
coincidentally, i just weighed my true duals yesterday and they only weighed 42# Total. now mine has an x, no cats, are only 2 1/2" vs your 3", dual flowmaster 2 chambers, & dumped before the axle also.
did you happen to weigh your duals after you took them off the car? i know you said you tried to keep the car the same for the before/after weigh in, but to save 50#+ and by eliminating only the pipes & X is very surprising because i didn't think tubing weighed that much.
did you have cats or cutouts on the dual setup that it weighed that much? it interests me but i think i would only save maybe 20# at the most.
Old 10-04-2007 | 12:46 PM
Matt D's Avatar
Originally Posted by PRAY HRD
hey Matt...
No, I weighed the car before and after, not just them. They were 3" duals with Sweet Thunders and dumped at the axle. I don't know why, but they were fuggin heavy when I took them off. Maybe they were regular steel. They came with the car so I don't know. The Magnaflows are very light though.
Old 10-04-2007 | 01:33 PM
romoranger's Avatar
have you guys had any problem getting the open loop tune right without a crossover? i can't get mine to idle once it warms up. i have only extensions off the collectors right now, but have an x-pipe setup i am getting ready to rig up
Old 10-04-2007 | 02:36 PM
TS6's Avatar
TS6
My TD's weighed a ton too. I didn't weigh them but mine have Dynomax super turbo's on them and are at least 50 or 60 lbs, dumped at the axle too.
Old 10-04-2007 | 07:55 PM
PRAY HRD's Avatar
wow, that is heavy! after hearing that 1 idle clip i'm not going to do it, it sounded LOUD! my f/m are pretty quiet and i've had a set of dual QTP cutouts sitting here for almost a year waiting to go on and may just add those to it.
Old 10-04-2007 | 08:00 PM
Matt D's Avatar
Old 01-26-2008 | 12:03 PM
NSTY WS6's Avatar
Funny, he said quiet. SSmoov1 has spiral flows with turn downs off the headers, it is much louder than the two vids posted. Mostly a street car with full interior, and you cant hear yourself think inside the car! I believe he is going to try a X pipe with the spiral flows to see if moving them back makes it better, but you guys say it doesn't change much?
Old 09-30-2008 | 09:32 PM
  #32
eric01ss's Avatar
hey matt d or bain how did u weld the mufflers up to collector or what did yall guys use?
Old 09-30-2008 | 09:42 PM
  #33
I used the band clamps on all my stuff. It makes working on the car easier in my opinion. Mine doesn't leak.
Old 09-30-2008 | 10:07 PM
  #34
eric01ss's Avatar
how much were your band clamps and u have a part # for them?
Old 09-30-2008 | 10:14 PM
  #35
TS6's Avatar
TS6
Just go to Napa or just about any parts store, they are about $10 each.
Quick Reply: 3" true duals VS Magnaflow mufflers off the collectors
