Drag Racing Tech
BS3 Wiring question
Old Jun 20, 2007 | 12:28 PM
Steve Burger's Avatar
LS1TECH Sponsor
Default BS3 Wiring question
I looked at the online PDF for this and ungerstand that they supply a new harness. My question is What do you do with the wiring already in the car?
Old Jun 20, 2007 | 12:45 PM
MADMAN's Avatar
LS1Tech Sponsor
Toss it. You dont use anything from the factory harness.
__________________
www.madmanandcoracing.com
225-343-9029
Old Jun 20, 2007 | 02:26 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
You can sell the factory harness for a couple of hundo.
You can piggyback bs3 over a stock harness to keep your gauges working in your '99.
Old Jun 20, 2007 | 03:06 PM
LS1TECH Sponsor
Does that mean the fuse block comes out too? The instructions are very sparse in what needs to stay.
Old Jun 20, 2007 | 04:06 PM
kp's Avatar
kp
You just replace the engine harness, unless you are rewiring the whole car of course. Part of the ECM harness is also used for the starter, fans and a few other things so if you remove it the car wont crank among other thngs
Speed Inc used to sell a plug and play harness for a BS3 to keep the stock PCM and guages, it was pricey though. Its not hard at all to piggyback them if you have a handle on automotive wiring. If you are doing race car wiring and aftermarkey guages then ypu can take out most of the stock wiring and put in what you need, the BS3 only needs a few wires hooked up to work, rest just plugs into the engine sensors.
Old Jun 20, 2007 | 05:26 PM
LS1TECH Sponsor
Thanks. Guess I will need to take a look and see where the engine harness is connected. I took a quick look today and did not see any place that it just unplugs.
Old Jun 20, 2007 | 07:44 PM
DMH Fabrication's Avatar
It goes into the firewall on the passenger side and hooks up right below the glove box in your car.
Old Mar 22, 2008 | 09:11 AM
theblur98ss's Avatar
So that whole bundle of wires and the pcm can be ditched? The only gauge I really need is the speedometer since I already have the rest. I could just do an autometer for that.
Old Mar 22, 2008 | 10:17 AM
LS1TECH Sponsor
I wil end up with a racepack dash.
Old Mar 24, 2008 | 08:14 AM
ty_ty13's Avatar
7 Second Club
sounds like a race car.... spend the extra 2 days and rewire the whole sum-bitch...
Old Mar 24, 2008 | 08:16 AM
ty_ty13's Avatar
7 Second Club
before you install it i will say... if you are going limited tire racing get the BS3 that is for a regular SBC that way you can use a programmable 7 box.... the BS3 version i saw late last year still didnt have the timing control i wanted... which pissed me off and drove me back to using a bbc, carb, and juice....
