3050lb 555ci BBC Vs 2850lb 408+n02
chassis is almost done and i have to finalize my engine choice.
What do you guys think will run faster in the 1/4?
15:1 comp 555ci BBC
Solid roller
Pro Systems Carb
Pro-filer Sniper Intake
Ported Brodix PB-2005 heads (570cfm intake/360cfm exhaust)
1.8 ratio PG/chance converter
14:5 comp 408 LS1 (9/16 head studs, 0-ringed deck)
Solid Roller
GMPP ls7 intake accufab/ 2100 cfm TB
Allpro LSW 12* heads Jessel rockers (375cfm intake)
1.8 Ratio PG/chance converter
As much n02 as it will take before lifting the heads.
Tire Will be
275/60/15 ET Street Radial
The class is running 8.1's 165+
15:1 comp 555ci BBC
Solid roller
Pro Systems Carb
Solid Roller
Tire Will be
Class max is 555ci.
For Big Blocks larger than 500ci their are no Power Adders Allowed,
BB smaller than 500ci are limited to 2 Solenoids for nitrous.
Heads where chossen for their Flow Characteristics and are one of the only Prostock style/Pontiac heads allowed.
Heads will be built with Ti Valves, Jessel Rockers, Jessel Lifters
Originally Posted by Beaflag VonRathburg
I'd like to get a set of All Pros now for my new motor. Where'd you get them, who ported, etc?...
Alex @ Cunningham Motorsports (CMS) Can answer any questions you might have.
Race your car!
I'd say go big block and make it a 496 like suggested, 2 solenoids with dual dry kits could get ya probably 300 hp of spray to it... no way that's not gonna be faster then a 555 on motor, especially with the head limitations.
I love ls1 stuff, but with what you want to do you'll have to push it farther then anyone has successfully done on nitrous so far, even if you can get it fast enough, it's not gonna stay together for long. To race a series like you want to do, you need reliability to keep things together..... you don't want to be tearing the motor down every week that's for sure.
Race your car!
I assume that a 555 n/a setup is competitive for the class.... if that is the case, a 496 with a 300 hit should easily outrun that, especially if the rules for heads and whatnot are the same, the loss of pwr you would have from going down 60CI vs what you would gain from a 300 hit are not even close, the 496 with a 300 hit wins every time. Especially if you can hook it out of the gate. But, with that tire limitation, I'm gonna guess you will have it set on 2 stages with a delay.
8 second club
I assume your 555 is the normal 4.560 x 4.250 = 555. Since you would have to change the crank and get different pistons anyway, I'd bore it to 4.600 and put a 3.75 (396, 427) stroke in it for a 498.
4.600 Bore x 3.750 Stroke = 498
or you would need a custom ground crank to come up with this for your current bore.
4.560 Bore x 3.825 Stroke = 499
4.560 Bore x 3.800 Stroke = 496
