Drag Racing Tech
help with traction
Old Jul 19, 2007 | 04:09 AM
daniel6718's Avatar
Default help with traction
the vids are labeled, but car like wheel hops off the line, i flash the stall on 125 normally and spin like this
i used to have 3.73 and 3200 stall and hit the 125 shot at 3500 rpm, now i try to flash the stall on 125 shot with a 3600 stall and 3.42 no luck
bmr relocation brackets on lowest setting, and umi poly poly lca's
i even tried flashing it with 75 shot then grabbing the 125 and it spun worse!
stock tq arm and stock springs/shocks
madman somebody whats causing this?
http://s21.photobucket.com/albums/b2...t=f49ed03a.flv
http://s21.photobucket.com/albums/b2...t=01db8302.flv
http://s21.photobucket.com/albums/b2...t=b0e8f0f6.flv
started the night at 15 psi cold went all the way down to 10 psi cold, tires are mt/dr
Old Jul 19, 2007 | 04:21 AM
So-GT0071's Avatar
Originally Posted by daniel6718
i used to have 3.73 and 3200 stall and hit the 125 **** at 3500
that made me laugh
I say you should get a torque arm since you have a stock one, they seem to help with wheel hop.
Here's a few options:
http://www.spohn.net/category.cfm?categoryid=1049
Jeg's and edelbrock have them as well on the jegs website
Old Jul 19, 2007 | 07:46 PM
daniel6718's Avatar
anyone else
Old Jul 19, 2007 | 09:05 PM
1SlowFormula's Avatar
Daniel,
What rear setup do you have? What I was hearing wasn't wheel hop as much as intermitant slipping, such as your LSD was not locking completely... Is it shaking the car on launch, and kinda giving you a feeling like your rowing the tires? (like a rowboat, right, left, right, left, right, left, etc...) That is normally the feel of wheel hop...
Old Jul 20, 2007 | 02:02 AM
daniel6718's Avatar
its a stock 10 bolt with 3.42 welded posi...i thought the same, as if one tire was getting all the power and almost enough to hold it but not quite...
no on the rowing feeling...its as if im in tire shake (both jump loose and grab lose and grab) the car sometimes will skate 1/2 inch or something one way or the other as its skipping...
the tq arm had the bolt holes stretched out a little last time i swapped rears so we pulled it out and welded washers around the holes for now, i know i need a new one but is that the problem for sure? i wanna get a body mount adjustable just kinda broke
weird i used to cut 1.50 (3200 stall and window switch at 3500)
now i flash a 3600 on 125 shot and it does this?, cars light too, should weight about 3200
Old Jul 20, 2007 | 10:13 PM
daniel6718's Avatar
ttttttt
Old Jul 20, 2007 | 11:05 PM
5_02ls1's Avatar
3.42 welded posi...
thev ole lincoln locker...lolid say its those stock shocks...
Old Jul 21, 2007 | 05:17 AM
junior28570's Avatar
Like 1slowformula said, it sounds like your slipping traction. Kinda' like your tires are skidding. I've seen it before on my car .. a long (longer than normal) burnout (maybe making the tires a little too soft) and tired track conditions (getting late in the evening) seemed to be the most likey cause(s). I dropped lost .05 off my 60' because of it.
Old Jul 22, 2007 | 03:48 AM
daniel6718's Avatar
well i used to do a burnout 1-2-3 shift to about 100 then let off...lately tires are getting close to slicks and i been doing a 1-2 to about 50 mph burnout, think thats not enough?
http://s21.photobucket.com/albums/b2...t=1f14fc08.flv
Old Jul 22, 2007 | 01:11 PM
Torkman15's Avatar
10 Second Moderator
Torque arm.
Old Jul 23, 2007 | 09:10 AM
Daniel,
How many passes and/or steet driving is on the M/T drag radials?
I know of a couple people who start having inconsistancy issues with them after 30 - 40 passes, mine are getting to that point and starting to do the same as yours...
Old Jul 23, 2007 | 01:40 PM
daniel6718's Avatar
they just got to where they have no tread all the way across...its weird i used to get .150 on them all day now i can barely get a 1.6
im about to get new ones and if i dont hook then a tq arm...
Old Jul 23, 2007 | 02:42 PM
fastenough's Avatar
5-6k miles on those things are they done (depending on how you drive on them)
Old Jul 23, 2007 | 05:58 PM
daniel6718's Avatar
track only...about 25 passes and they were used about 8 or so before that i think...
prolly 300 street miles....they just got through the tread and have been slick for about 5 pases...i dont know how long they last once the tread is gone but i figured they would hook better now that they have more contact patch?????
Old Jul 23, 2007 | 08:16 PM
slowredz's Avatar
You need new tires.... I noticed them at Yello Belly yesterday and they are done. What all did you get tickets for?
Old Jul 24, 2007 | 12:10 PM
daniel6718's Avatar
have i met you or seen you? i know your car lol....im looking into getting some...i just figured they were better when they got bald guess not
trailor tags, safety chains, no break away device and brakelight not working...
Old Jul 25, 2007 | 11:25 PM
slowredz's Avatar
I dont think we have actually met. That sucks on the tickets, that's a bunch of B.S stuff
Old Jul 25, 2007 | 11:31 PM
trembles's Avatar
i have seen on more then once that when you weld the diff and use stock axles the axles twist back and forth causing the car to wheel hop or feel like the tires are shaking
Old Jul 26, 2007 | 01:12 AM
daniel6718's Avatar
yea i had a flat about a week ago and it knocked off tha tag and ripped the wiring for the lights...have got to fix it yet....i need some money for new tires..
why wouldent it do it with a spool in a stock rear then?
Old Jul 26, 2007 | 07:26 PM
JEB99TA's Avatar
At first, I had aftermarket LCS' and P/H bar ... still had wheel hop. I then bought a set of 4 of the older style HD Bilsteins and never had a wheel hop problem again.
