Looking to fix my bad combo...suggestions?
I've done quite a bit of research, and a lot of checking other people's results. The best solution I have is to go with a 3800/2.2 converter, 3.90 gears, and the TRak cam
I'm not worried about top end (i.e. 140+) on this car, nor am I worried about "drivability" (I have another car to daily drive...this one is driven on weekends mostly, sometimes once a week to work). However, I think that 4.10/4.11 gears would be too steep, as I would run out of gear a bit too quick
So what do you guys think of that combo? Anyone have something better? My shorter term goal is to hit 11s on the engine, then spray it to see 10s. Later on when I have more money I'll do more engine work to try and hit 10s N/A, but for now 11s is good enough
2) a 4000 stall (if it truely stalls at 4000) is NOT too big for that hotcam. a 200 rpm difference in converter wont make any difference at all.
3) gearing only matters what sized tire you are running. i run 3.73+28" radial and its as much gearing as i want. my car 60' well. 1.5 on the motor, 1.3 on the jug
4) your th350 has more gearing than my th400. nothign lazy about it at all.
what are your track results? why do you think its so bad?
I took the pan off today, and there was a pretty good amount of metal flakes on the drain plug. I'm thinking between a rebuild and a fresh converter, most of the problems should be taken care of. The trans was not rebuilt before I put it in the car, and I have no idea what kind of abuse it took before I put it in (was in a time bind back then, and I had to get it in asap...but I have all the time in the world now)
