lightweight battery
http://www.beiterbattery.com/ETX14.htm
it seems to be the same as the braile without the price.
http://forums.vwvortex.com/zerothread?id=2353060
DEKA is the manufacturer of the Braille labeled battery - fact.
the Braille and the Deka etx14 are the exact same box - fact.
the Braille and the Deka are the same design (based off of the schematic)
the Braille and the Deka weigh the exact same - 11.4 lbs - fact
the Deka tests the same as what the Braille is claimed to test at - 360-400CCA- fact.
http://www.stealth316.com/2-dynabatt.htm
hmm looks like i found a new battery to get....SWEET
What do you use to hold it down? (and pass Tech)
Is it going to cause you starting problems in extreme heat or cold?
https://ls1tech.com/forums/drag-racing-tech/678618-installed-odyssey-pc680-today.html
https://ls1tech.com/forums/showthread.php?t=678618
That looks good but I plan on relocating to the rear.
First as some others have pointed out you don't want to move a small lightweigh battery to the rear, too many issues normally ensue...
Secondly if you are looking for something to relocate, why be concearned if it has side posts???
Intresting. I was hoping to clean the engine bay up a little but I guess it makes sense not to add all the wire weight.
I was going to find one with sideposts so I could use GM style connectors.
