is it gonna be safe to run this setup without sfc,s???
my new setup is full bolt ons crane cams 224 cam 4000 stall 373 gears and a wet shot ive got 75/125/and 150 jets..and will be spraying off the line probly the 75 jets..
Ive got about 5 buddies tellin me im crasy if i run this car without frame connectors...ive seen a few 3rd gens twist the body but do i need to worry about it with this setup????
any help thanks
x2Its a lot cheaper then replacing a T-Top when it comes flying out...
Or a door and hatch that won't shut.
Squeaks and rattles galore coming your way.
David
how many of you are running without sfc.s and how hard are you launching
So far the car is still strait and everything lines up. I'm sure it wouldn't be a bad investment though.
Ive put so much money into this car in the last month and its killin me to not know what its running........
my question is, should i remove these slp diamond sfc and shed some weight
Maybe not remove the entire framt connector... but maybe cut the diamond part out of the canter. I'm in the same boat right now, I see a ton of people that just run the bmr style that run along the otuer edge of the frame and they are fine, epsecially with a rollbar/10 pt in the car. I've been cinsidering cutting the diamond portion off, and I think I'm about ready to do it.
