Drag Racing Tech
SFI 25.2 Mustang/LSx build "The Renegade"
Old 12-05-2007, 11:28 PM
  #281
RAGENZ28's Avatar
What's up with the update phil?
Old 12-06-2007, 08:30 AM
  #282
T Pizzle's Avatar
Whens she goin for paint ????
Old 12-06-2007, 09:45 AM
  #283
ls2 bait's Avatar
a guy i know has a mustang drag car and i was looking at it today. he has the cobra nose and back bumper but didnt change the rockers and side scoop and it doesnt look right. id would def look into it after seeing that car.
Old 12-07-2007, 10:23 PM
  #284
7 Second Club
Phil99vette's Avatar
First coat...
Second coat..
Custom aluminum radiator hose
Old 12-07-2007, 10:29 PM
  #285
RAGENZ28's Avatar
That's looking awesome Phil
Old 12-07-2007, 10:42 PM
  #286
7 Second Club
I'd like to thank Harlan for taking the time to help me through my tig problems. Did the things we talked about and the aluminum welded perfect. Thx man!
Old 12-07-2007, 10:43 PM
  #287
7 Second Club
I can tell you this, the cage pics don't do the paint justice. Its looks killer and I have not done the clear yet.
Old 12-07-2007, 11:16 PM
  #288
RAGENZ28's Avatar
LOL I have never seen a 3 stage paint job on a cage, you're the man phil.
I hope mine comes out that nice, if not can you come fix it
Old 12-08-2007, 03:25 AM
  #289
JUICED96Z's Avatar
Looks good, might want to cap off or cover the accusump line openings to keep dirt out of there.
Old 12-08-2007, 09:20 AM
  #290
T Pizzle's Avatar
Lookin badass Phil
Old 12-08-2007, 10:05 AM
  #291
7 Second Club
The paint was very tricky it naturally comes out VERY thick, if you don't keep it moving it will run. Decided to do 2 coats to make sure I have good coverage. I used adhesion promoter on the door bars to make sure they stick good. The clear coat will make it shine and bring the metal flake out.
Old 12-08-2007, 10:10 AM
  #292
chvyeter's Avatar
Awsome build, but don't you know there's no room for the a/c condensor with that huge snail in the way
Old 12-08-2007, 10:16 AM
  #293
7 Second Club
Come on, have you ever heard of rear mount?? I'm going to put the AC condenser in the rear.
Old 12-08-2007, 10:41 AM
  #294
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Crack the windows and use God's air conditioning
Old 12-08-2007, 01:45 PM
  #295
7 Second Club
Update on parts that are on the way, hopefully final round:
Dedenbear Co2 Setup(Jegs)
Instant fittings(Mcmaster Carr)
1/8" NPT Bung for valley cover
Jegs Aluminum Co2 bottle Mounts
Lokar Powerglide Dipstick firewall mount
Mickey Thompson Drag radials
Old 12-08-2007, 01:59 PM
  #296
T Pizzle's Avatar
What size Drag Radial did you go with
Old 12-08-2007, 02:12 PM
  #297
7 Second Club
325/50/R15
Old 12-09-2007, 10:48 PM
  #298
RAGENZ28's Avatar
Get any work on the car done this weekend? I posted some new photos in the mini tubbing section, man i have a tin can on wheels
I must have pulled close to another 20 pounds out maybe more, that has to be close to 100pounds removed from this pile, now I need to start lightening up the front to get the weight back even.
Old 12-09-2007, 11:05 PM
  #299
7 Second Club
Didn't get much done this weekend...
- Used a piece of 6" aluminum tubing 18" long, cut a 1/2" section out to make a inlet on the bumper for the turbo. Got the bumper cut and than trimmed the aluminum tube so it contours the bumper
- Milled ~.015 off the back of the pistons, just used a round aluminum burr and milled a groove between the wrist pin, have about .020 of clearance now
- Cleaned the block for assembly
- Cleaned/Hung the rods on the pistons
- Tig welded reluctor wheel to crank
- Dropped the crank in the LSx block, installed main caps and completed 2 torque sequences
- Drilled remining holes in the valley cover and pre-fit 1/8" bung for oil pressure
- Ground off fill tube from valve covers to weld on Aluminum fill bung and cap
- Touched up a couple areas on the cage where the paint was thin
- Mounted fenders and front bumper back onto car to go to paint
I'll get some more work done tomorrow morning before work.
Old 12-09-2007, 11:43 PM
  #300
RAGENZ28's Avatar
That's cool at least you did some thing, it all adds up if you stick with it.
Post more photos soon I love seeing the progress, it is good motivation
Quick Reply: SFI 25.2 Mustang/LSx build "The Renegade"
