SFI 25.2 Mustang/LSx build "The Renegade"
#4486
Do you still run the intercooler or are you going to ditch it?
If anyone is interested in my old Aeromotive Eliminator fuel pump and some fittings let me know. Its barely used as we never really got a chance to test with the 2nd fuel system. Its maybe ran for a total of 1-2 minutes.
#4488
Man if this stang wasn't bad *** enough, now it's going to be fueled by alcohol. What kind of power increase numbers wise do you think you will see phil? Or to make it easy what are you e.t. goals? You gonna try and ****** that 4.58 record away from our local boy Kevin? He is doing the same upgrades you are right now. He's going methanol and ditching the Fast for BS3 and 225 and 500 lb. injectors along with other air flow and data logger upgrades.
#4489
#4491
Slowly getting there....
Rear end fabrication is done and its painted, just need to assemble the rear end
Built a 3/8" stub driveshaft for the fuel pump
Got the new fuel pump mounted and ready to go
Joe simpson is working on a 3 gallon methanol fuel cell
Intercooler pipe is done
Joe O. sent me some Moran 500# injectors to go along with the Precision 220s I currently have
Fuel tank is going to be 3 gallons, anodized, 1.25" outlet to the fuel pump
Still need to get my tranny freshened up
Intake O-ringed
Pickup a Peterson -12 to 4 (-8) distribution block
I didn't want to do a bunch over the winter so its pretty close to running once I get the fuel tank. I also am going to pull the motor and work on the drive side shock tower to gain more clearance for plug access.
Intake O-ringed
#4496
Looks Awesome Phil, just make sure you dont rush. I want to see what this girl is capable of when you finish putting the final touches on it...
I hope you have had time to spend with the wife and little one this off season cause once that thing is ready it will be game on, all the haters will be set on kill Phil...
#4499
Nothing big, just working along. Did some small stuff
- replaced the rotors
- fixed a rubbing issue with the rear brakes
- BS3 is back and installed
- tore down the glide this morning to fix the front seal, check the band and clutches, everything looks brand new, had some very very minor scoring on one piece but nothing major.
- started plumbing the fuel system, its going to be a plumbing headache but its almost done
- Shawn is going to O-ring the intake manifold
- the fuel tank is almost done
#4500
Any ideas on a power goal next year?
