Drag Racing Tech
SFI 25.2 Mustang/LSx build "The Renegade"
Old 05-21-2012, 09:19 PM
  #4621
minytrker's Avatar
Watching this build from the beginning its crazy where it has come. I honestly would have given up long time ago with some of the setbacks you have had. But if there wernt people who didnt push like you then records would never be broken. Its cool to see you stick with the LSX vs just ordering a cookie cutter big block setup.
Old 05-21-2012, 11:37 PM
  #4622
fenton06's Avatar
It won't just be records that are broken... phil is gonna be breaking hearts everywhere!
Old 05-22-2012, 04:14 PM
  #4623
defbob's Avatar
Originally Posted by Phil99vette
Yep, they all are expensive, on this last build, I would have gotten a johnson or anderson 525 hemi instead of the LSx.
Don't worry, I'll let you know how well a Hemi performs in ODR...
Old 05-22-2012, 04:23 PM
  #4624
7 Second Club
Phil99vette's Avatar
We will see. If it performs as planned, yes it will hurt some feelings. @ 2750 it should go 6s but who knows.
Old 05-23-2012, 05:41 AM
  #4625
Broke EF's Avatar
I always thought a mag generated its own spark and didn't need a coil?! Car is looking great Phil, not put that thing on a track!!!
Sean
Old 05-23-2012, 06:45 PM
  #4626
Fbodyjunkie06's Avatar
Sean
Gotta get the juice to fire from somewhere!!!
Old 05-23-2012, 11:08 PM
  #4627
Wnts2Go10O's Avatar
bah, phil will have the first LSX hemi before that happens >.>
Old 05-27-2012, 06:07 PM
  #4628
Cam72aro's Avatar
You testing this weekend or did you take it off? Ready to hear what this sucker will do.
Old 05-27-2012, 08:48 PM
  #4629
7 Second Club
Ran out of fittings, need to get 2 90s for the top ports on the heads and 3' of 12 hose for the fuel line.
Old 05-28-2012, 12:32 AM
  #4630
8 Second Truck Club
Blown06's Avatar
Damn that thing is busy looking, but looks real good.
Old 05-29-2012, 08:42 AM
  #4631
ATVracr's Avatar
10lbs of **** in a 5lb bag. LOL !!
Old 05-29-2012, 10:54 AM
  #4632
I'd say phil quite surpassed the 10lbs of **** mark on gasoline!
Old 05-29-2012, 02:09 PM
  #4633
AChotrod's Avatar
Your #1 plug is in the wrong spot. lol JK Car looks stellar~
Old 05-31-2012, 06:20 PM
  #4634
7 Second Club
I fired it up yesterday and with only changing the mag44, the A/F went from 4.5:1 at idle to 3.9:1 at idle and it no longer spits fuel while its cold. Going to get it buttoned up and hit the track next week.
Old 06-01-2012, 06:08 AM
  #4635
McLeod's Avatar
Sounds good Phil. I hope the air is good.
Old 06-03-2012, 09:58 PM
  #4636
bad6as's Avatar
did you get to the track?
Old 06-03-2012, 11:36 PM
  #4637
7 Second Club
No, I can't get the car to fire on the BS3. Been working on it all day trying to figure out whats going on. For some reason, the RPMs are jumping all over the place while its cranking using the BS3 to trigger the mag. Once I figure out the erratic RPM problem I think it will be fine.
Old 06-04-2012, 05:15 PM
  #4638
BSmiff's Avatar
Sucks this monster keeps giving you problems. Going to fly when it decides to act right.
Old 06-04-2012, 06:48 PM
  #4639
outlawdart's Avatar
I have had trouble with a 8973 box keeping the mag from firing and I pluged the Mag back into itself and tool out the 8973. It fired up just fine so I knew it was a problem with the timming box "8973". Never used the BS3 to manage the Mag44 so not sure what your problem is but take it out of the loop to fire the engine and that will make sure the rest of the Mag setup, "points box, coil, and Mag" is not a problem
Old 06-04-2012, 10:11 PM
  #4640
7 Second Club
f**king just figured it out. The pink wire on the BS3 was getting a dirty signal and was causing all the issues. With the pink wire hooked directly to the battery, all of the issues go away.
Quick Reply: SFI 25.2 Mustang/LSx build "The Renegade"
