Drag Racing Tech
Neutral safety switch?
Old Sep 26, 2007 | 07:17 PM
JaSSon's Avatar
Default Neutral safety switch?
What do I do with the wires to get my car to start? I just put in a Hurst pistol grip shifter and it doesnt have a spot for the wires. Should I wire them together or put a switch on it to get past tech?
Old Sep 26, 2007 | 07:41 PM
pmbmax's Avatar
Well i will tell after you see a 6 year old get run over by his mothers car while his uncle was working on it . MAKE IT WORK I was tunning on my car looked up and saw somthing under a car and people running and to find out it was the kid bleeding out of every hole in his head hadand had to air lift . and race was called. The purple wire is the one you want to switch you can find it at the harness b4 it goes thru the fire wall with the computer wires.
Old Sep 26, 2007 | 08:00 PM
SLowETz's Avatar
There's a N/S switch you can buy for that's specific for that shifter.
http://store.summitracing.com/partde...5&autoview=sku
Old Sep 26, 2007 | 09:27 PM
BTLFEDSS's Avatar
My Hurst Pistol grip came with a N/S Switch on it.The black plastic piece on the front of the shifter.Had to prongs on the way bottom hard to see.If it helps
BTLFEDSS
Old Sep 27, 2007 | 02:44 AM
smoknta's Avatar
My Hurst Pistol Grip also came with one.
Old Sep 27, 2007 | 11:44 AM
JaSSon's Avatar
I bought a rear exit shifter but there is some kind of switch with one spade sticking out of it and a arm that goes to the main shaft of the shifter. If this is it how and what wires do I hook to it? I assume my factory nsw was the pigtail with the green/white stripe and brown/white strip. How should I hook this to the one spade? Thank you everyone.
Old Sep 27, 2007 | 03:17 PM
BTLFEDSS's Avatar
There is a spade on the very bottom that is real hard to see,because thought mine only had one aslo.Its just way underneath.Directions i think show a little pic i'll have to look at mine
BTLFEDSS
Old Sep 27, 2007 | 03:35 PM
JaSSon's Avatar
What wires do I hook to the spade to get car to start and safety switch to work? This is an A4 to A3 conversion btw.
Old Sep 27, 2007 | 03:55 PM
JaSSon's Avatar
I see the spade on the bottom and it was hard to find. Which wires go on what spade? I think someone said purple and light green.
