Best drag racing Trany
I have a new project, a 94 Firebird, V6 that had an Engine fire so I 'm going to turn it into a drag car so I don't ruin mine daily driver.
I will be useing a LS 6 and I need to know what trany would work best for drag racing.
The LS 6 will be a carb setup, not fuel injected, straight turn key and race.
I'm looking to get down into the 9's so I want a trany that can with stand the pwr.
I want to stay away from computer controled stuff as much as posible.
Thanks
PG trans only if its a car that needs to be toned down off the line. Given the tranny ratios, you need to make so much power that the tranny gears tone down the over all ratio and keep the car on the track.
Before I think anyone else can input on this, you need to be more specific on power level expectations. There is a tranny for nearly any situation.
Pwr adders will be anything from N2o to a blower or turbo.
I'll probibly start with N2o and build up from there.
I want something that I can put in and will work for a long time.
I don't want to be changing tranys all the time.
I hope that's good enough?
Here's one of many results on glide versus TH400 searches: www.ls1tech.com/forums/showthread.php?t=624440&highlight=glide+400+or#pos t6058986
1-weight savings
2-less power loss
3-tames the launch versus the 3-speed's 1st gear
Glide disadvantage:
1st gear is numerically lower versus a TH400 so street driving MAY be a little harder away from a light depending on gear and converter choice (again, I said MAY as each set-up is different), as well as more heat in certain situations due to same reasons.
Again, it's by choice. Plenty of bracket racers swear by the glide, but plenty of heads-up guys use 3-speeds for keeping the rpm more in the powerband versus the 1-2 gear drop in the glide.
Derek
Or at least that's what I'm doing this winter.
And I have plans to put the 6 speed back in after a few years of dragging it with the A3.
One site swears by the Th400 hands down.
Villian, thans for the break down that helps me a lot.
As far a street driving this, I highlly doubt it.
On more question:
Is there any thing I will need to adapt the Gluid or TH400 to the LS 6?
A GL is a great way of toning down a VERY fast car so that it will leave consistantly and if the driver needs to accerlate, they can. Most cars that run a given index (lets say 10.50's) are often faster ***** out then what they run so that they can control their times.
If the races is heads up, why not go with something that as long as the combo, weight, suspension is properly designed, should allow for a faster time given the car is running longer in the power band.
I beleive which ever way you go, the car will be fast.
So in the end i went with the glide and if i think i can go faster with the 400 i will switch. so i say go with the glide
Kurt
Also, TH350 are not the choice for a transmission with a transbrake. Yes, they are out there and yes they work. But ask most serious bracket racers and they'll tell you a TH400 or glide is much more consistent off the t-brake.
And coming from a 16-year veteran of footbraking, transbrakes are very cool
This is why I spent close to 2 grand converting my car for one and yet it doesn't run any faster than the TH350 did.They're out there, but looking at the #s not even close to the majority. I'd run one, but I know the maintenience involved and the "always possible missed-shift" with a stick you don't run into with an automatic. If my Nova was not bracket raced like it is, I'd seriously consider a 5-speed for the fun factor.
Derek
