Drag Racing Tech
Suspension help needed, settings to get into the 10's
Old Oct 9, 2007 | 04:02 PM
FASTFATBOY's Avatar
Default Suspension help needed, settings to get into the 10's
Here is my Combo
94 Z
383 Solid roller LT1
4L60E, 4300 converter
4.11 gear
325/50 drag radial
465 rwhp, 436 tq
Spohn tq arm
BMR K member
First generation HAL QA1's up front
Koni Double adjustables in the rear
Stock rear swaybar, no front swaybar
Airbag in RR spring
Raceweight 3780 lbs
The car has only been to the track once, best was ....
60 ft 1.58
1/8 7.15@95
1/4 11.25@120
I only got 5 passes in
Settings on that pass were
Rear tires 12 psi
Front shocks loose as possible
rear shocks as installed(neutral)
airbag empty
Leaving at 2000 rpms flashing converter.
The track was crappy when I ran that ET.
I think I should have a tenth or so to get out of 60ft, where should I start on rear shock settings? I have KONI double adjustables on the rear.
Thanks
David
Old Oct 9, 2007 | 04:26 PM
MADMAN's Avatar
LS1Tech Sponsor
What part number Konis??
__________________
www.madmanandcoracing.com
225-343-9029
Old Oct 9, 2007 | 04:52 PM
FASTFATBOY's Avatar
Bryan, part number 8242-1006SP1, I know you are gonna nail me on those shocks, but I got em and gonna have to work with them. Afco's are kinda out at the moment.
Don't you think this car should 60 ft in the high 1.40's?
David
Old Oct 9, 2007 | 07:49 PM
flyinZ's Avatar
Put that car on a diet You've got 10's in that car, just give it time, and some messin' with the suspension.
Old Oct 9, 2007 | 09:20 PM
FASTFATBOY's Avatar
There is a few things I can do, not much though.
Put in some Kirkeys, remove the door bars, passenger airbag, thats about it.
It is a streetcar so the Kirkeys I dont want, I could stand to lose a 100 lbs LOL.
David
Old Oct 10, 2007 | 06:24 AM
MADMAN's Avatar
LS1Tech Sponsor
That looks like a road race shock Dave. How many sweeps in the top and clicks in the bottom do they have.
__________________
225-343-9029
Old Oct 10, 2007 | 02:06 PM
chrismorales75's Avatar
I'd guess around 1.47-1.48 60ft with a 10.90's et. You should take a video of the car at the track so we can all see how it is leaving.
BTW why run an airbag empty?
Old Oct 10, 2007 | 02:44 PM
FASTFATBOY's Avatar
Well it was one of those deals where I was trying different things. The car at first was wheel hopping....I was just trying different things that night.
I will leave it with 15-18 lbs and drop the tires to 12 and see what happens.
David
Old Oct 11, 2007 | 09:09 AM
FASTFATBOY's Avatar
I weighed the car on 4 corner scales, this is with a full tank of fuel and 15 psi in the right rear airbag.
No driver
LF RF
992 881
LR RR
743 854
With driver
LF RF
1099 913
LR RR
880 900
Thoughts?
Bryan, BTW, I have BFG 325/50 drag radials, can I rotate them side to side? There is no rotation arrow on the tire.
David
Old Oct 11, 2007 | 09:20 AM
Brady's Avatar
LS1Tech Sponsor
20# heavy on RR w/driver is a good starting point. stiffen the shocks for wheel hop. Pinion angle?
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Old Oct 11, 2007 | 09:32 AM
FASTFATBOY's Avatar
Everything in the rear is heim ended, I got it at -2.0 at the moment. Stiffen compression or rebound or both? I was gonna start with tightening compression
David
Old Oct 11, 2007 | 11:55 PM
SSwanner's Avatar
David
probably compression.
were you riding around on 90 @ CTC friday afternoon? your car have a cage in it?
Old Oct 12, 2007 | 05:55 AM
FASTFATBOY's Avatar
Yes, that was me.
I went down Wed night and came back Sunday, put 450 miles on the car.
David
Old Oct 12, 2007 | 06:12 AM
Brady's Avatar
LS1Tech Sponsor
glad to see this motor outlived the last one
__________________
2016 Z07 Carbon
Old Oct 12, 2007 | 06:40 AM
FASTFATBOY's Avatar
So far he he, the gas package is coming soon!
This car has tested my sanity, what little is left.
Hey how about that 3x Madman shirt?
I am going to Irvington tonight to play with the suspension, come on out.
David
Old Oct 12, 2007 | 08:12 AM
Brady's Avatar
LS1Tech Sponsor
It's at Tommy's.
Probably coming out tomorrow to test- putting the car back together today.
__________________
2016 Z07 Carbon
Old Oct 13, 2007 | 11:44 AM
Wonder why your car is so much lighter on the right front???
I scaled another car I had and it was only 5-10 different from one side to the other, you have a big *** hidden turbo on the side
Old Oct 23, 2007 | 09:43 AM
FASTFATBOY's Avatar
Here ya go Chris, it doesn't APPEAR to spin the tires, almost like the converter is too loose.
http://www.youtube.com/watch?v=1JiQrB39TNI
I try different things, I have not adjusted pinion angle, it is at -1* because all of my rear is heim ended, nothing moves really.
I tightened the rear shocks to full firm on compression, didnt really effect it much.
I can get it down to consistent 1.58's, everything I try from there either makes it worse or has no effect at all.
David
Old Oct 25, 2007 | 02:57 PM
4300 stall??? It isn't flashing very hard. What are you doing when you stage it??
Looks like you aren't pre-loading the chassis much, ever think about trying a 2 step hooked up to the brake so you can have it floored and then as soon as you let off you have full throttle?
Do you have adjustable lower control arm brackets?
What are the front and rear shocks set at?
Old Oct 25, 2007 | 03:28 PM
FASTFATBOY's Avatar
Leaving just off idle, about 1100 rpm. I thought about a two step. Lower control arm brackets are in the bottom hole. Front Hals are full loose. Rear Koni's are set rull hard on compression 1/2 way on rebound.
David
