Battery Relocation + Cutoff questions
High Amp Alternator Shut Down Relay Kit
P/N - 764-50105
This kit, comes complete with 250 amp solenoid and two 10' sections of 8 gauge wire, will effectively handle alternator feedback of the highest amperage alternators. Eliminates engine run-on when the master disconnect is turned off.
so we would make a pull on the dyno than we shut the car off to tune go start it and it wouldnt start due to the injectors not having enough power.
so i had to eliminate it
The alternator would run to the side of the cut off switch so no power is running to the battery when it is in the off position.
So no matter what once you hit the switch off, even if the alternator is powering the battery, the other now off side will see no kind of electrical charge and it kills everything.
Cheap drawing lol don't laugh it gives you the point.
Also it is nice to have a big button next to the shifter you can just push that will kill everything at once so you're not looking for switches if you know you're about to kiss the wall lol.
So let me get this right:
8 ga. from Alternator direct to battery will work fine????
I have 2 ga. running to a distrubution block up front and then 6 ga. for starter and Acc. post.
Thanks again!!!
As far as the 2ga, then 6ga to the starter, I just run one 2ga to the starter, I would run the 6ga wire from the starter to the distribution box if you went smaller. That starter needs a full size cable from battery to the starter, on mine I went 2ga to starter and 4ga to in-car kill switch, then 4 ga to my distribution box, then used the appropriate size wires from there.
I also put all my stuff on separate relays, fans, water pump, fuel pump 1, fuel pump 2, n20, lights, ign, that way the switch panel doesn't take the hit and it is only used to turn on and off and the relays which are made to take the current gets the abuse.
