Drag Racing Tech
Mini Tubbing
Old Dec 22, 2007 | 01:19 PM
  #281
RAGENZ28's Avatar
Originally Posted by Phil99vette
Why don't you weld them? Is this the same deal as mini-tubbing since you did a full tub?
Phil
Mini tubbing you still have 1/2 the outer wheel tub in place, so the structure is still there.
When you put in a full tub, the only thing around it is the outer body skin, which in a drag car will slightly flex, over time if you tack welded the tub to the outer body the tacks would break.
So you weld a full tub to the frame and brackets and leave the outer edge that meets the body and use silicone there.
A mini tub you can weld the tub to the frame and inside of the 1/2 of the factory tub left, since it isn't going to flex.
Here are two photos you can see the difference in metal with a mini tub there is still a lot of the factory structure and with a full tub it's a tin can with screws LOL.
Also mine are not welded mine are aluminum but even in steel you don't weld in a full tub to the outer body.
GTG TTL..
Attached Thumbnails Mini Tubbing-0186913-r1-032-14a.jpg   Mini Tubbing-0188732-r2-022-9a.jpg
Old Dec 22, 2007 | 08:25 PM
  #282
JasonWW's Avatar
Originally Posted by RAGENZ28
You do "NOT" weld the tub to the outer body metal.
You leave a 1/8th" gap between the tub and outer body metal and use silicone.
OK, it just seems wierd to think the tub is not solidly connected to the outer fender. So would the silicone maintain a good seal and keep out water and noise? I'm thinking that a little flex might break the silicone seal.
Old Dec 22, 2007 | 11:02 PM
  #283
RAGENZ28's Avatar
The whole point of using silicone is so that the seal doesn't break, silicone will flex with the body, it dries and acts like glue plus is very flexible and will seal out water, being it is water proof and won't absorb water.
Tack welds don't like to flex, but keep in mind this flexing is very small, it's not like your body panel is going to be moving back and forth 1/2" or something.
You cut out all of that material and use a full tub it is going to flex slightly.
Old Dec 24, 2007 | 01:54 AM
  #284
RAGENZ28's Avatar
trimmed the plastic panels by the sides of the seat, easy to cut, takes LOTS of trimming over and over to get it to fit right.
Old Apr 24, 2008 | 05:02 PM
  #285
RAGENZ28's Avatar
Anyone else mini tubbing that has stuff to add to the post?
Old Apr 24, 2008 | 09:22 PM
  #286
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Do you have any finished pictures? The furthest I've seen is the passenger tub in and painted with the rear seats still in.
Old Jan 5, 2009 | 10:01 AM
  #287
IllusionalTA's Avatar
Very informative thread.. i'm contemplating undertaking this on my own.... Great Thread guy's..
Old Jan 27, 2009 | 09:05 AM
  #288
RAGENZ28's Avatar
I cut mine all apart, it's sitting in the garage, my buddy is making a twin turbo SBC in a 2600 pound nova, pre-turbo weight so I had to step mine up =)
Bad thing is he has the money and is buying the parts and I don't. Car looks like my icon.
As far as doing the mini tubs it's a fun project and you can fit a nice size tire and lower the car a bit for a nice look, but then again I like building and tearing stuff apart.
Old Feb 5, 2009 | 01:11 AM
  #289
nemss1's Avatar
need some opinions. im building an extremely lightweight strip car stock internal bolt-on car
ive cut out the sheet metal that holds the rear sail speakers. there is a bracket that looks like its for structural integrity. im not tubbing or putting a cage in my car
could i cut that bracket and still have good structural integrity to launch a 350RWHP car without wrinkling my exterior fenders???
so far, i was told not to cut it unless i plan to cage. want more opinions
Old Feb 5, 2009 | 01:14 PM
  #290
FASTFATBOY's Avatar
Originally Posted by stroked30th
Mine looks exactly like this one.
Old Feb 5, 2009 | 01:15 PM
  #291
FASTFATBOY's Avatar
Pics of what you are talking about?
Old Feb 5, 2009 | 03:42 PM
  #292
nemss1's Avatar
dont have a working cam at the moment but i will try and describe it to the best of my ability. piece looks like it adds structural integrity. starts at the top of the factory tub and runs up to the roof area of the car. right behind sail panel sheet metal. piece im talking about also has the door striker attached
Old Feb 5, 2009 | 07:24 PM
  #293
FASTFATBOY's Avatar
I would not cut that out no. That is part of the cars structural rigidity.
Old Feb 5, 2009 | 08:35 PM
  #294
nemss1's Avatar
thanx man, thats what i figured
Old Mar 3, 2009 | 02:41 AM
  #295
Kguy's Avatar
reading through all the pages and i have a quick question...with the wolfe mini tub kit and relocating the LCA's ill have around 16 inches of clearance?
Old Apr 30, 2009 | 02:43 PM
  #296
RAGENZ28's Avatar
If you relocate the LCA's and use the wolfe mini tub kit you'll have close to 16", the next thing you'd get close to rubbing would be the panhard bar bracket. I narrowed mine and boxed it in.
Old Apr 30, 2009 | 08:38 PM
  #297
Ego Killer's Avatar
how can you relocate teh LCA's?
Old May 8, 2009 | 11:32 PM
  #298
RAGENZ28's Avatar
I moved my shocks in, narrowed the frame and moved the LCA's between the frame itself and the inside of the LCA bracket, then you'd move the lca brackets on the rear end. If you look there are photos of it moved inside.
Look at post 277, picture 5 top right, you can see the lca in the stock location, but you can also see where I sectioned the frame and where it can mount even further inside of that.
If you look at post 201, the 3rd photo shows the stock LCA bracket and how the LCA in mounted between the frame and lca bracket itself.
Old May 9, 2009 | 09:34 PM
  #299
OWN3D BY MY PROF!
^ Since this has been brought back from the dead... Have you made any progress on your tin can project?
Old May 18, 2009 | 11:04 AM
  #300
RAGENZ28's Avatar
Just been sitting in my garage haven't had time. I'm back in school and planning to move in the next few months, so most likely it'll start after I move. Looking forward to working with some family in the oil industry so money should really pick up.
Depends a lot on if I get a new bike. I might race the bike for a bit while I take my time on the car. Either way still the same plans, tub frame, big tire twin turbo.
