Mini Tubbing
What used to be in this circled part:
BTW, is it going to be a full rollcage or just a rollbar in the rear?
My 99 TA doesn't have that. I believe the 98's used a metal gas tank, so maybe that is the black box that now sits on top of the plastic tanks?
You going to cut out the other brackets?
No the body won't tweak or twist until you get more into cutting, cutting out the tubs won't do a thing, you brace the car when you start cutting out the floor in between the body, like a full tube frame set up, but as long as you have the floor in the car the body won't move around.
Let me draw a quick pic so you can see what I mean.
except personally i would move the x in th door so that the front upper bar is where the front supports attach to triangulate that better, and it looks like you are going to use a hoop in the back from the main hoop to the standoffs(i didnt know what else to call them) you may need to bend that to clear the tubs, and also either way i would gusset it to the main hoop, also x in the back?
The hoop doesn't have to be bent to clear the tubs, they only go up to the top of the hatch ledge.
The main thing is keeping the back seat so my kids can ride with me =)
It will look kind of like this, then later on I will add the rest of the bars when I remove the floor down the road.
That's quite a bit of material there. Thanks for the pictures with the updates.
I already have the plates for the frame cut out and all the pieces I am putting back in so I will weigh everything hopefully and have the weight saving numbers in by this weekend.
Plus down the road I don't have to touch or redo a single thing, pull out the rear seat, weld a few more bars in the car and I have a car good to 7.50's.
The way I will be doing it will be good to 8.50's so I doubt I'd run that fast ever anyways, wouldn't want to, I just want to add gas, check the tire pressure and make some passes, then go home and drive it to the store, to eat and around town and park it.
When I do my turbo motor one day it will be a LSX block, 6 bolt cylinder heads and a nice big turbo that makes max power around 6000 rpm on pump gas, when I want to go race I'll add some race gas and boost and knock some passes off. When I do that I will most likely run a th400 and a small stall something around 3000.
I'd be happy to have a car that will run 9's and drive on the street anytime I want.
2 straight bars and an "X" is like 1970 pro stock stuff LOL, I am going with a hoop and the two rear struts.
You're just trying to sabotage my dope street car project and make me turn to the dark side "FWD"
As of now the plan is as follows, but I doubt I will add any more bars.
You keep forgetting the car only makes like 400 hp right now
If so That wouldn't be something I put in until it is a dedicated race car, I don't think that would leave much head room in the back seat right now
Nothing new for my kids, I was picking them up from elementary school and they were climbing over x door bars getting in 5 points LOL.
Total weight saved 53 pounds
Drilled the hole through the frame to remount the LCA, what a fricking hassle to get it straight, got that done looks like it will take a 6" bolt, also went to 1/2 bolts and enlarged bushing holes to 1/2. You'll have to remove the fuel filter on the frame and move the fuel line over some to drill the drivers side.
Will post new pics next week.
