where to start?
Not sure what tire you are on, but that will effect this somewhat as well. If you are on a 28 inch slick, start them off about 13 psi and see what that gets you, you may be able to run a touch more air in them then that, but don't go any lower then 12 because the car will get real unstable like that. If you are running a 275 lb spring it will be even more unstable feeling at that point.
the pinion angle is fine there, but I personally would start it off a little less, you don't ever really want to go any more then -3, so being at -2 you're already almost all the way there. I'd put it at -1 and start there, I played with this some as well this year and found -1.5 on my car worked out the best, putting more in it didn't help any, but it worked better at -1.5 then it did at -1.
Hope this helps some.
Your car bogged BAD on that run.... the car looks like it needs alot more gear to really run n/a, or launch way higher so it won't fall off so much. Maybe try airing the tires up some, better to have it spin a revolution and hook then have it fall on it's face like that.
I'd put the tq arm in the middle, then you can try moving it up and then try it lower too, see what it likes.
