Drag Racing Tech
My new drag toy. 93 lx coupe carbed LS1/th400. (pics)
Old 11-26-2007, 08:20 PM
Z06PSI's Avatar
Very nice.
Old 11-26-2007, 11:05 PM
taqwache's Avatar
ford tuff with chevy stuff, i like it.
Old 11-30-2007, 12:33 AM
JRracing's Avatar
I got all the interior removed for the roll cage to be installed. I'm also patching the big hole in the floor for the shifter and another one near the rear seat were a drive shaft did some damage to it.
I'm also welding in some TQ box reinforcement plates for the upper and lower control arms. And welding in a CM anti roll bar on the rear.
Here are some pics with the interior out.
Old 12-15-2007, 09:14 PM
JRracing's Avatar
I did a few things this week. I got the UPR anti roll bar welded on and the old SFC's cut off to make way for the through the floor SFC's. I still have not got the car started yet. I can not get it to fire. No spark. I thought the msd 6ls was bad but I sent it in and they said it was fine. I will have to check the wiring again.
Old 12-15-2007, 10:16 PM
donkey mule's Avatar
Very nice! Post some #'s when you get it running. I bet you it will be a beast!
Old 12-16-2007, 10:27 PM
JRracing's Avatar
Here's a few more random pics.
Old 12-20-2007, 10:43 PM
JRracing's Avatar
Well I got the upper control arm plates and the patch panel for the shifter hole welded in over the last few days. The welds suck *** but are very strong and get the job done. I need to finish up the lowers now and that is it for the rear suspension work.
I'm going to paint the entire bottom of the car with por 15. Also going to do the cage and inner floor pan once it comes back for the cage guy doing the cage work.
I just got the msd 6ls box back from them. It checked out ok. So now I need to find out why it does not want to start. I'm getting a laptop pc next week so I can put the software on it from msd. It has power and ground but no tach signal.
I just bought a used meizer race pump and adj alt bracket. So I will be selling my meizer street pump. $400 shipped if someones interested in it, PM me.
If the motor checks out ok, I may just pull it to put in the camaro with the ls6 int and Torquer v3 cam. Then go ahead and built this 383 short block I have and put it in the mustang with the T Rex, afr 205's and vic jr with the 750 demon carb. Boy, would that be nasty!!!
I'm not sure just yet.
Old 12-20-2007, 10:53 PM
Kingsize's Avatar
Looks good! It even has a Chevy Emblem in the dash! Maybe even Ford knows there engines suck... I wanna see this bitch with her nose up!
Originally Posted by JRracing
Old 12-21-2007, 03:14 AM
Nimitz87's Avatar
good **** man...glad to see it sworking otu for you.
your rearend is going in tom if all goes well.
Chad
Old 12-22-2007, 11:46 PM
JRracing's Avatar
Chad
Good luck. Enjoy it, it is a serious rear end. I have a stock little 10 bolt ready to go back in. LOL.
Old 12-22-2007, 11:56 PM
Nimitz87's Avatar
yup...10 bolt is out, now im thinking I may just sell it as is w/ the brakes on it and get some nice drag brakes...
but being its a 6 speed I need to keep the emergency brake. was looking at the Aerospace street kit. if it clears 15" rims looks like those will go on.
Chad
Old 12-31-2007, 05:55 PM
  #32
JRracing's Avatar
Default Update
Well I got the upper and lower control arm reinforcement plates on and welded up some holes in the floor. I also pulled the hood and left fender and frt bumper to start on the wiring nightmare. I think I'm going to gut all the wiring and put in a painless race car harness with switch panel.
I also still have not been able to get the car running. The msd box is not putting out any spark. I even tried re wiring it with no luck. MSD customer support has been of no help. They said get a laptop, so I did and it has windows vista on it and the usb to serial cable driver is not compatible with vista. So now I need to hook up an old desk top to it with 98 or xp on it and try again. I'm sick of this ****. I feel like I'm wasting time, but I want to hear it run before I pull the motor to put in my camaro. So I can start building my 383 for it.
Here's a few pics. Check out this wiring hack job. And no it was not me who did it...
Old 12-31-2007, 05:59 PM
  #33
JRracing's Avatar
Old 12-31-2007, 06:24 PM
  #34
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Wow, that wiring caused my OCD to kick in big time
Can I come down and fix that right now for you?
Old 12-31-2007, 06:36 PM
  #35
JRracing's Avatar
Please do! HAHA.
Old 12-31-2007, 09:26 PM
  #36
spatton100's Avatar
Beautiful Car!
I too am building one and am running a super vic intake and am quite concerned with hood clearance since its about an inch taller than the vic jr. How close is your hood to the filter, and is it a dropped design, can't tell from the pics.
Old 12-31-2007, 09:39 PM
  #37
JRracing's Avatar
Are you talking about the hood being a pin on? No, it's on the hinges. I'm not sure how much clearance there is once the hood is closed. But it clears fine.
Old 12-31-2007, 09:44 PM
  #38
slammer454's Avatar
nice toy! do the leaves help traction any?
Old 12-31-2007, 09:47 PM
  #39
spatton100's Avatar
Now I check that off the list of potential problems. Thanx.
Did you figure out the MSD problem if not is it possible that the circuit the MSD power is hooked too cuts out when you hit the starter, just an idea..
  #40
842ta's Avatar
if you dont mind me asking what did you give for that beast?
Quick Reply: My new drag toy. 93 lx coupe carbed LS1/th400. (pics)
