16" slicks.
First off I know i'd be better off running some 15" rims all in due time.
looking for either a 16" d/r or full on slick. preferably something like MT streets but they dont make them.
looking for a 28x10x16.
i'll be pushing it to the very max w/ a 26" tall tire as far as RPM goes i'd be crossing the traps 200rpm under redline....not looking to do that as im going to spray soon.
car has Moser 9 31 spline axles, 4.11's,qa1's, UMI dbl adj. lca's and phb
is the Hoosier the only tire I can run for now?
what about the fitting these tall tires?....
Chad
Chad
Chad
Chad
Hoosier quick time DOT Pro is hoosiers version of the ET Street and they make a 28x10 16"
Hoosier 17603QTP - Hoosier Quick Time Pro D.O.T. Drag Tires Details
Tire Overall Diameter: 28.0''
Average Roll Out/
Circumference: 88''
Tire Tread Width: 10.0''
Tire Section Width: 11.8''
Wheel Diameter: 16''
Required
Wheel Width: 8'' - 10''
Tire Weight: 24 lbs.
People fit 28x10's on stock wheel wells, but it is hard to say because I don't know how good the stock rim fits with a tire that tall, If I had to guess I would say the major point you'd have to look for is on the inner front for rubbing.
Nothing a BFH hasn't fixed many times.
Average Roll Out/
Circumference: 88''
Required
