- Camaro and Firebird Aftermarket Performance Modifications<br>Overview of popular modifications to customize your Camaro or Firebird.
"Weight Reduction List" Fully Updated!
I ran 165/85r/15 radials on my car for a few years. They were Kumho brand. They each weighed 17lbs. I switched to the Moroso 2-ply bias tire. They each weigh 9lbs.
radial 165/85/15.......17lbs (each)
Moroso MOR-17050.....9lbs (each)
Saves 16 lbs unsprung weight
They aren't legal on the street though, and they won't last a real long time either, also not recommended for full-weight cars at all, use discretion.
Z06 18x10.5s w/ 305-35 nittos weighed 54 lbs each (almost worn to the wear strips)
Z06 17x9s w/ cheap 275s weighed 56 lbs each (brand new)
did not understand the 18s being lighter, so the nittos must be fairly light for their size
........................ drilled and slotted rotor........ 10 lbs
aerospace brakes. caliper w/ bracket and pads... 8 lbs
..........single disc race rotors w/ aluminum hub... 5 lbs
Lexan sitting next to it. just Weighed it......10#
Stock Hatch w/o glass(mine window got busted outta it) 58#....just weighed it also
So......
10 Lexan Window
8 Hatch - VFN Hatch 93-02 is posted as 8# on their site
2 hardware
20# total
EDIT
Stock
58 Hatch
30??? Glass maybe
... hatch dampeners & hinges
... hatch lock/latch
88#
So depending how far off i was on guessing the window weight it came to 68# weight reduction
SO IF ANYONE HAS A STOCK REAR WINDOW FOR A INSTALL U SHOULD TOTALY WEIGH IT
88
CHECK OUT THIS LINK FOR MORE INFO
https://ls1tech.com/forums/drag-raci...runk-area.html
Stock steel LS1 1998 to 2002 hood with brackets and insulation=51 lbs 8 oz.
2002 OEM SS hood with brackets=51 lbs 4 oz
Both hoods repainted once.
Weighed with a certified, legal scale.
so these weight are all dropped off? or the weight of the part itself?i just want to confirm that one more time please.
10e.A-Arms (BMR mild steel)
13e.A-Arms (stock)
38..Catback system (Hooker) lose 38 pounds?
3...Chromoly LCAs
3/9.Carbon fiber driveshaft 3/9?huh?
14..Chromoly A-arms like the post stated above you lose 14lbs! by going chomoly instead of the mild steel at 3lbs? are these bmr also?
25..Chromoly K-member
so 42lbs off nose for chromoly lca,a-arms,k mem?
