- Camaro and Firebird Aftermarket Performance Modifications<br>Overview of popular modifications to customize your Camaro or Firebird.
"Weight Reduction List" Fully Updated!
https://ls1tech.com/forums/drag-raci...itch-diet.html
VFN Sunoco pin-on hood- 14.802 with side lips, no added holes or faseners.
Panhardrod brace- 4.980 with the 3 bolts, nut and the small heat sheild bracket for a 7mm bolt.
EVAP-4.635 rear over tank crap, purg noild/black lines/choarcoal canister. not any of thereast of the car metal lines and crap.
http://i2.photobucket.com/albums/y11...n/DSC02619.jpg
SLP 2OTL mufflar 22.70 with both tailpipes/tips, no over axle tube-
2001 Z28 cloth seats nothing changer, removed and weighed
driver /power- 39.15
passanger /manual- 29.85
Kirkey 17" prostreet/drag with cover and racrcraft brakets 17.545 (each) ready to bolt in, unpainted seat
http://i2.photobucket.com/albums/y11...n/DSC02636.jpg
FINAL WEIGHT SAVINGS OVER STOCK
Driver- 21.605
Passanger-12.305
33.91 saving in the seats, And a LOT safer with the rollbar, and harnesses then using them with a stock seat.
Kirkey prostreet Drag 12.13 17inch pn-41700 no cover each
Kirkey seat cover- 2.455 17inch, black cloth/tweed, each
http://i2.photobucket.com/albums/y11...n/DSC02632.jpg
Racecrafter kirkey seat brackets- 6.045 Bolt In style, 1 driver 1 passanger (pair)
http://i2.photobucket.com/albums/y11...n/DSC02630.jpg
RJS 5point harness, camlock 5.805 (each)
http://i2.photobucket.com/albums/y11...n/DSC02633.jpg
front seat belts- 6.696 with the bolts
http://i2.photobucket.com/albums/y11...n/DSC02620.jpg
harnesses are 1.76#'s lighter then that stock belts
speedinc carpet 12.910 out of the box, not cut to fit, with matting.
Wolfe 6point 4130 weld in- 58.701 low door bars, rear thu specker bars, wolfe jig notched.
51.98 welded hoop/seat/rear over seat bars, 1 5/8 seat bar, non welded doorbars and plates to floor at that time. legal 1 5/8th seat bar is lighter then the 1 3/4 wolfe ships, And over the seat rear bars are lighter then the longer thu speaker holes style
Stock LS1 Kmember with engine stands 57
BMR Kmember reg style, with LS1 egine stands 25
stock m6 torque arm- 14.6
BMR full lenghts adj. torque arm 21.2
10bolt- 150 My stock 10bolts 150 right on the money, driand fliud 3;42 gears
S60- 196 Same parts on it as the 10bolt, dry, 3:73 gears, true trac
S60 parts
truetrack- 46
strange "lightweight" pro race spool- 13.2
32.8 saving with a spool over the truretrac
LSX intakes
LS1- 9.8
fast 78- 11.2
bbk 85- 24.8
Driver- 21.605
Passanger-12.305
S60 parts
truetrack- 46
LSX intakes
LS1- 9.8
fast 78- 11.2
bbk 85- 24.8
Strong and heavy, but surprisingly efficient.
Bolts up to all of your existing components except for the driveshaft.
Here's mine as it arrived this summer. Came with a 3" CM driveshaft and Strange racing brakes.
I have 3 good LS F bodies plus a wrecked 1 & all have bad window motors so when I get arount to fixing the windows in my fast car with a cage I plan on converting to manual windows(if I can find everything I need). Its a street/strip car thats more like a strip so I dont need the power & figure all the wiring & motors may ad up plus with ud pulley I dont need the draw on the alternator.
I'm using a good digital shipping/nitrouse scale. gose to like .000 pound or grams even, not some lamo 0-10-20-30 bathroom turd.
Robbie posted up ther other day the hardtop/Ttop roof info. Huge props to him for checking back in and doing all that work.
t-tops and t top roof....... 31.24 lbs
hardtop roof without the metal pieces needed for the outside roof area.... 14.90 lbs
Figure the metal pieces that need to be welded in are around 5 lbs for the factory ones, then the hardtop should be around 10-12lbs lighter. not to bad.
I'm assuming that your weights are with the glass removed?
