- Camaro and Firebird Aftermarket Performance Modifications<br>Overview of popular modifications to customize your Camaro or Firebird.
"Weight Reduction List" Fully Updated!
If I take the brackets off will that hose be fine without that bracket protecting it on the driver side..
What will I benifit from taking the front sway bar off..Thanks Jimmy.
The LS1 factory power steering cooler in the upper rad hose is 3lbs
The TA Passenger seat leather with lumbar pump is 42lbs
Dual fans are 14lbs and a 16" single is 9 so saves 5lbs
my pin on sunco is more, and thats just a 2inch cowl skin, with nothing under it. just single fiberglass layer
what singal fan are you taking about. i heard there was some earily 90's v6 has one fan, or you have a aftermarket one
I see many weights offered for the Leather F body seats... are there Definite weights for the driver and passenger TRANS AM seats with full power, lumbar etc?
Afco front 14 inch 275# springs, 11.5# pair
Stock 02 WS6 T/A rear springs, 11.0# pair
Weld RT-S 15x4 w/ M/T 26 inch S/R radial
30.5-31 pounds per rim/tire combo
I can honestly say these are a great deal, 15x4s for $225 each. They look great!
I know ETs/mast cathy, are very noticeable more. Like maybe 6# for the pair, but thats kind dumb like bigger piston weight. haha
Took this the other day let somone test fit my front wheel. I should do a rear but there bagged, and wraped in blankets in a pile a parts for winter storage still.
Greg weld 15x3.5 with a moroso DS2 26x4.5x15 22.4 each
http://i2.photobucket.com/albums/y11...cture006-2.jpg
15x3.5 Prostars w/165 R15 radial tires = 26.6#'s each
15x8 Prostars w/26x10.5x15 ET Streets = 28.6#'s each
Bogart Aluma Light 15x3.5 w/Moroso DS-2: 19.5
Pro Star 15x3.5 w/Steel Belted Radial: 25.5
Bogart Aluma Light 15x10.5 w/28x10.5 ET Drag: 34.5
Pro Star 15x8 w/27.1x9 ET Drag: 31.0
