- Camaro and Firebird Aftermarket Performance Modifications<br>Overview of popular modifications to customize your Camaro or Firebird.
"Weight Reduction List" Fully Updated!
PC680 was fine another year, bigger cam now too. The battery starts the car, the alt. keeps it running, If your car stalls with it running, the alt.or something in the electrical system, or the tune sucks.
21..AC fan motor (entire assembly) where is this located at..Because if I didnt take it off I want to Thanks Jimmy..
stock 2001 fans and radiator weight 21.2 #s (with the hoses (no PS cooler))
Stock 2001 dual fans in the shroud 11.7-11.8ish
Removing the 2nd fans blade and motor brings them to 7.4. (4.1 saved Free
)singal SPAL 16" (PN 2049) 5.0 pounds. 6.7 saving over the dual fans
Stock 2001 radiator (manual) is about 9.5
Quick time LS1 bell housing with SFI window, block plate, and bolts is 29.8 pounds
Just the bell housing with the window bolted on is 25.4 pounds
Stock alum t56 bell housing (GTO) 8.2 pounds
anyway ive been searching for the weight difference between iron and aluminum blocks...
i came up with the iron block being 85lbs heavier...damn does that sound right...?
4l80e- wet 255
4l60e- wet 175
TH400- wet 140
TH350- wet 130
Powerglide- wet 110
I wonder what the weight difference is between a non and a lockup stall
my lockup10"4l60e verter felt noticably heavier than the non lockup th350 10" converter...
wish i would have weighed the 2...
4l80e- wet 255
4l60e- wet 175
TH400- wet 140
TH350- wet 130
Powerglide- wet 110
RHS...............110
Dart Billet......128
6.0L Iron.......220
LSX...............230
These weights are quoted from here: http://www.yellowbullet.com/forum/sh...d.php?t=480958
I have weighed three LS1/LS6 blocks on different scales and all were 95-100lbs with the caps. So the 6.0 liter is more like 120lbs more.
6.0L Iron.......220
