Drag Racing Tech
LPE 2 step considered "electronics" ?
Old Jan 20, 2008 | 05:39 PM
A_VAS's Avatar
Default LPE 2 step considered "electronics" ?
I see a lot of tracks have in their rules listings....for classes that are 'no electronics'.
Is putting a LPE 2 step for instance, on your M6 car going to be considered electronics at most tracks?
I'd like to use this piece for launch rpm control, instead of doing the look at tach, look at tree, look at tach, repeat if you know what I mean.
Old Jan 20, 2008 | 06:18 PM
kp's Avatar
kp
Generally 'electronics' means delay boxes. Check with the track to be sure, usually 2 steps are allowed.
Old Jan 20, 2008 | 07:49 PM
WickEdSix98's Avatar
With a manual car, a two step would be allowed and at some tracks its legal in auto's also.(hooked up on the brake pedal) Some tracks also allow transbrakes w/o delay boxes in no-E as well but it varies with location.
Old Jan 20, 2008 | 08:20 PM
Matt D's Avatar
Retired Street Racer
2-steps are allowed and so are trans brakes. You just can't use a delay box or throttle stop.
Old Jan 20, 2008 | 08:22 PM
slammer454's Avatar
not to hijack but what is a throttle stop?
Old Jan 20, 2008 | 08:24 PM
Nimitz87's Avatar
think its used for bracket racing...holds the throttle at a certain % down the track to consistently run the same times w/o breaking out. don't quote me though.
Chad
Old Jan 20, 2008 | 09:49 PM
MetallicaMatt's Avatar
I thought it was pretty much a 2 step but for carbed cars
holds the throttle at a certain position while the pedal is to the floor
Old Jan 20, 2008 | 10:40 PM
A_VAS's Avatar
Thanks for the replies guys....I talked with one track here (Beaver Springs) and they said yes for a 2 step on a stick car. They are IHRA so I just wasn't sure if NHRA or other events see it the same way.
I'll be putting the Lingenfelter unit on soon.
Old Jan 21, 2008 | 06:19 PM
NUTS95Z's Avatar
I run NHRA and they do not allow 2-steps or airshifters in no electronics in our division 2.
