Drag Racing Tech
Lexan Windows, Who has them?
Old Jan 26, 2008 | 11:20 PM
SMKN TA 95's Avatar
Default Lexan Windows, Who has them?
When I was pulling the motor out today, I noticed that my factory windshield has a 12" crack right up the middle of the glass. I dont want to spend the money for a stock glass and have the weight....so I would rather upgrade to Lexan and lose a few lbs.
I know VFN makes windows for the car. Clear 1 makes a molded set, and so does Percy's Speedglass. The Clear 1 windshield saves you 50 lbs over a stock glass windhsield.
Who is everyone using? Madman? Burkhart? Anyone?
Old Jan 27, 2008 | 07:36 AM
MADMAN's Avatar
LS1Tech Sponsor
I use ProGlass. They are pre molded. I also have used VFN and they are of the same quality
__________________
www.madmanandcoracing.com
225-343-9029
Old Jan 27, 2008 | 09:55 AM
Shawn @ VA Speed's Avatar
I've used the Speedglass-fit great
Old Jan 27, 2008 | 11:20 AM
mrdragster1970's Avatar
6 & 8 Second Club
Harwood, VFN.
Old Jan 27, 2008 | 06:34 PM
jason02Z's Avatar
i was thinking of putting some lexan in too.. are they water proof, well i wont be dring in the rain but in case its out.. any pics?
Old Jan 28, 2008 | 01:03 PM
SMKN TA 95's Avatar
I called Pro-Glass since they are only about 1 hour from me. VFN is also local too.
Madman, do you remember how much trimming of the windshield is needed to make it fit properly? Whats the easiest way to cut this stuff?
VFN is far cheaper than Pro-Glass, 395 at Pro Glass versus 285 at VFN. But I want to make sure its going to work and not have any issues with it.
Old Jan 28, 2008 | 01:08 PM
MADMAN's Avatar
LS1Tech Sponsor
I use a jigsaw with a 18 teeth per inch blade. Then I sand to final fit. The all come about 2" to big all the way around.
__________________
225-343-9029
Old Jan 28, 2008 | 01:21 PM
bowtierodder's Avatar
who has the rear hatch lexan? sorry
Old Jan 28, 2008 | 01:32 PM
SMKN TA 95's Avatar
All of the companies listed above sell the rear hatch lexan.
Old Jan 28, 2008 | 01:52 PM
6 & 8 Second Club
Don't forget, especially for a windshield. There are more than one thickness, & some have a special finish for scratchproofing. Don't just ask price, ask what style you are getting for that price. I got the top of the line for the windshield, and the cheap stuff for the rest. Just a thought.
Old Jan 28, 2008 | 02:14 PM
SMKN TA 95's Avatar
From Pro-Glass I priced the top of line line coated winshield @ $395
From Clear One I priced the top of the line windshield with the MR-10 coating @ $430.
From VFN I priced the top of the line MR-10 coated windshield @ $285.
What gives on the price difference? VFN and Pro-Glass are local to me (50 miles), and clear one needs to be shipped.
Old Jan 28, 2008 | 02:17 PM
sr71bbjr's Avatar
I have front and rear lexan from VFN.Madman did the install.Came out great.
Old Jan 28, 2008 | 02:28 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
On firebirds how are you guys mounting the hatch and lexan rear window?
Old Jan 28, 2008 | 03:43 PM
that looks good , did he just use the install kit they sell? sealant/screws? did it need alot of trimming? oh and it can be installd on a stock hatch right?
Old Jan 28, 2008 | 09:47 PM
LSGunZ28's Avatar
Holy crap 50 lbs savings? thats a great way to save weight. and beautiful T/A BtW
Old Jan 29, 2008 | 12:49 AM
ls1408cp's Avatar
I was going to do a pin on hatch with lexan in the rear but on firebirds you need to make a custom wing of some sort. I am just going to install the lexan in the stock rear hatch. I saw a ta that had it in kanascity but didnt get to talk to him about it.
Old Jan 29, 2008 | 10:21 AM
ALLBOTTLE's Avatar
LS1TECH Sponsor
ls1408cp- do you plan on attaching the hatch and lexan to the stock hinges? I don't think the lexan would be strong enough to support the weigh and if you make it a pin-on the size and overall weight might make it damn near impossible to take off on your own, just a thought.
Old Jan 29, 2008 | 11:03 AM
MADMAN's Avatar
LS1Tech Sponsor
I use 8x32 countersunk screws and either use nuts or drill and tap all the holes.
__________________
225-343-9029
Old Jan 29, 2008 | 02:36 PM
Steve Burger's Avatar
LS1TECH Sponsor
I would not be afraid to go the VFN route. We do a lot of business with them and have had great success.
Old Jan 29, 2008 | 02:44 PM
so, you used nuts on the screws? i was planning on just drilling holes through the window and screwing the window to the trim of the hatch.
