Lowerd cars hows your sixty foots ?
#43
best short ever 1.38, average short is 1.50
car is @ 1.5" lower all around. qa1 kit up front cut v6 springs rear qa1 shocks
the full bmr line up is under the car exept for a stock rear sway bar.
17" mt drag radials
can see the stance and the short times in this vid
http://youtube.com/watch?v=rCb0vLo-N7E
17" mt drag radials
#49
How much does cutting the rear springs affect the spring rate ect. I have heard of some people cutting their rear springs and then having trouble hooking the car afterwards.
#50
Cutting the springs should not affect spring rate. Spring rate is mostly affected by wire diameter, pitch, and type of material used. Except when the coils start stacking out on each other, then spring rate might be affected.
#52
Nice thats I wanted to hear. I'm going to look in to the BMR's. What size MT are you running ? Are your fendors rolled just want to know whats needed with the car being slammed.
#56
Eibach Sportlines dropped me 2.5" with 275/40/17 MT et street radials. I have LCA relocation brackets but they only set the control arm to level and they were not enough for me. I tried em but just couldn't hook with a best 60' of 1.9x so I cut a coil and a half off stock rear springs and that raised me up an inch. Since then consistent 1.6x 60's and now its the clutch thats limiting me from going quicker its dead hooking. I've had other issues that have kept me out of the 11's but I've had plenty of MPH for it I just have yet to make a clean pass now that its launching well. I'm swapping to 4.10's this season to ease the load on the clutch and hope to get into 11.8 range all motor.
I'm also going to modify my LCA brackets and weld on another step for a fourth hole so I can keep my sportlines and not have to swap springs around which is a pita.
#59
Cam, 1BADAIR thats the info I was looking for basicly you both went slower when the car was dropped to much. I was thinking about the sportlines but I heard they were to much of a drop. Thanks guys
