Lowerd cars hows your sixty foots ?
I'm looking to lower my car because it sits to high in street trim but I don't want to hurt the sixty foots. The front is not a problem I have the Hals and can adjust height. I just need some springs for the back that aren't to stiff.
My car is a 383 LT1 put down 468 rwhp na I plan on hitting it with 200 shot.
I know that there are alot of you guys that are lowerd can you help a brother out ? thanks
1. what kind of springs ?
2. what is your sixty ?
3 any info on your combo that you feel would be usefull.
4 pics are always good.
Street trim sits like a 4x4.
Drag trim not so bad but could be better.
That's a nice sixty foot for a 17in drag M6 car. I will be running a 28x10.50 tire for the track. Anyone else ?
1. what kind of springs ? I run 2 1/2" X 10" coil over springs 150# rate
2. what is your sixty ? Best 60 FT 1.30 Nitrous 377 / 250 shot / th400 (old combo)
3 any info on your combo that you feel would be useful. If the car is the average weight drag car, I would run a 150# spring, if it is heavy or really high HP you might try a 175# spring, I doubt you'd get the car light enough to run a 130# spring. Set up your shocks to 50/50 if you use C/E rear shocks, or #5 to start with if you run a QA1/Hal type shock, double adjustable shocks start with both settings on 5/5.
4 pics are always good. I don't have many pics since I haven't taken any since the tubs I put in, but my fender lip to the ground is 26 3/4" off the ground.
Here is a pic, car is actually lower now.
Wow your car looks great slamed nice color to. What rpm did you leave at ? Do you feel you could improve your sixty with a set of 28x11.5. I'm really hoping for atleast 1.3's
Just an thought, what if you picked up a second set of stock rear springs and cut them a little bit? At least this way if it doesn't work and wont hook up, you aren't really out much money and you've always got your originals to go back to.
I'm strongly considering doing this on my build.
RAGENZ28 nice info. What size converter you running ? I'm running a th400 to with a 4000 nitrous converter. What's your pinion angle set at.
Rogue86 , that's not a bad idea. I have considered doing that I'm just looking for some more info from guys that have race proven experience with their lowered cars.
Car was a little slower than it would have been, I really needed a 5,500 on the motor and more gear, but on the nitrous it was all go
I have got all the good suspension stuff done but I was told that with lowering springs which tend to be stiffer you might not get the proper weight transfer needed which could result in poorer sixty fts.
I doubt 28s would fit under. I had to roll the lip and massage the inner fender a bit. The tires still rub a tad on launch. It squats quite a lot with these springs. I rev to ~5500 and get off the clutch fast. I'm surprised it has done 1.5x with the weight and M6 and a 3.42 gear.
