Lowerd cars hows your sixty foots ?
#61
A tube chasiss car is sitting on the ground but has no problems hooking.
This is Rick Intrau's old car, it sits on the ground, notice how far the rear mount of the lower control arm is away from the rear end to give the angle back. This shoves the tire into the track.
![](http://images.gmhightechperformance.com/features/0510htp_turbo_09_z.jpg)
![](http://images.gmhightechperformance.com/features/0510htp_turbo_07_z.jpg)
David
#62
Exactly. Easy fix if you can lower the rear of the control arm but I have relocation brackets installed ( I think they are BMR but cant recall ) and they dont allow enough arm drop. Hence why I am modding them to drop even lower by welding more plate around and adding a fourth hole. This way i can stay bitchin looking and maintain true street trim and still hook hard when i hit the track
#63
actually my car sits lower with the cut stock springs and it was quicker. I know of another local that swapped out the eibach springs for cut stockers and his 60ed better and more consitant that way too. He also drilled another hole lower in his relocation brackets to get the LCA angle cause his car is very low
#64
David
#65
#69
Thanks to everyone who replied to this thread. I got some good info for the car.
Would have liked to seen some more pics of all those bad lowered rides though.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#71
this is the cars current best pass 8.73 on a 1.35 short time, car weighs 3825# now
here is that pass
http://videos.streetfire.net/video/8...-MM_201441.htm
just last saturday i got a new best short time, this is on a 295/45/17" drag radial (1.33 short time)
here is that pass
http://videos.streetfire.net/video/1...els_680086.htm
couple more recent pics
![](https://ls1tech.com/forums/attachments/drag-racing-results/178402d1241313264-1-33-60-17-rims-tires-pic-dsc05241.jpg)
#75
I'm gonna bump this 4 year old
thread for some more recent input. It interest me because I'm on DMS lowering springs, stock deCarbons LOL, and lca relocation brackets.
Best 60' on motor 1.66....I need to get that down.
Would some cut stockers be better? or pre1998 V6 springs? or...?
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
#76
I did make new brackets and got the geometry sorted out but with sportlines there is just zilch for transfer, from a dig its a joke i blow off 2 gears worth of 275/40/17 et street MT DR's.
Best set up was stock V6 rear springs and low hole on the brackets. Works out to about 4 or 5 degrees down bubble on the rear arm and it was dead hooking with the same tires. Car needs coil overs now theres just no super low stock type spring im aware of that transfers worth a damn for drag racing.
