Drag Racing Tech
Racing with the heater on helps?
Old Feb 15, 2008 | 12:45 AM
Camaro396's Avatar
Originally Posted by foreverzero
Iv'e heard some people say that turning your heat on actually lowers your E.T. because it helps remove heat from the engine...I know running your car with the A/C on hurts the times, but I have never heard of running with the heat on....Im calling but has anyone else ever heard of this?
Actually running with your A/C on will not affect your times, as the compressor shuts off a WOT.
Edit: Nvm someone already said that haha
Old Feb 15, 2008 | 09:28 AM
John_D.'s Avatar
Running the a/c might push up your coolant temps some though.
Old Feb 15, 2008 | 04:29 PM
foreverzero's Avatar
Originally Posted by John_D.
Information on alternator loading:
Simple Version
http://www.alternatorparts.com/under...lternators.htm
REGULATOR
The regulator has two inputs and one output. The inputs are the field current supply and the control voltage input, and the output is the field current to the rotor. The regulator uses the control voltage input to control the amount of field current input that is allow to pass through to the rotor winding. If the battery voltage drops, the regulator senses this, by means of the connection to the battery, and allows more of the field current input to reach the rotor, which increases the magnetic field strength, which ultimately increases the voltage output of the alternator. Conversely, if the battery voltage goes up, less field current goes through the rotor windings, and the output voltage is reduced.
Techie Version:
http://www.inderscience.com/storage/...1167102389.pdf
Page 7
Chart showing mechanical energy required to produce electrical energy, based on a 42V 5 kW alternator. 3000 watts mechanical = 2500 electrical. 5000 watts mechanical = 4000 electrical.
etc.
I didnt think the answer was gonna be this technical! Thanks, it all makes sense now
