Ok I've heard that some people have a better E/T when they shift at 5500 insted of 5800 or higher.. is this true?
heres my dyno sheet if it helps any..
The claim is certainly not true for your car. You will minimize your ET by shifting several hundred rpm beyond your power peak. In your case this is probably above your rev limit. If you don't want to raise the limit, try shifting at 6300.
raise the limiter to 7 or 7200 and shift at 6800, thats were im shifting at. and you need to do the same cause your leaving alot on the table if you shift lower then 6k
-brandon
-brandon
I'd like to see how the power carries to 7k on your combo but from what I can see you should be shifting at 6600 at least. Raise the limiter and wind it out.
Larry
Larry
I just dont want to blow the motor the bottom end is all stock. I'm wanting arp rod bolts just havent got any yet. I've got a fast 90 that I just bought and I'm getting new injectors, fuel rails and NW 90mm. so maybe then I can put some in and get a nother tune and bump it up or something. I'll get a 150 shot also.
Quote:
Put the limiter at 7k and try shifting at 6700rpm. No guts=no glory.Originally Posted by BlackSS2001
My rev limiter is set at 6500 12 Second Club
I would think you can safely take it up to 6800 judging by your parts list but I wouldnt take it past that, the answere is how far down does your revs go when you shift? It looks like peak torque is at about 4800rpms, so I would aim for as close or slightly lower as you can to that, without going past 6800 to get to it. You just have to experiment and see where ur revs go after you shift. but your strongest powerband looks to be from about 4600 - 6400 but hp doesnt drop after 6400 and appears to seem like it should be a flat curve to 6800+.
I'm with Demonicbird00 and ZV8. Shifting at 6800 rpm's will keep your rpm's from dropping and having the car regain momentum. I'd set the shifts at 6800 and the rev limiter to 7000. When mine was stock bottom, I hit 7000 rpm's quite a few times and it didn't hurt anything ... not saying it couldn't have, though ... def wasn't good for it. Instead of throwing more power to it, if I were you, I'd look at getting your motor forged. , but, that's just me.
Good luck.
Good luck.
Quote:
I agree, with that curve your optimal shift point is going to be beyond the stock bottom end's capacity to handle it. Originally Posted by Gary Z
You will minimize your ET by shifting several hundred rpm beyond your power peak. In your case this is probably above your rev limit. If you don't want to raise the limit, try shifting at 6300. Go as high as you feel comfortable and remember that a spun bearing is
a good excuse to build a forged 355 or 383
FWIW; I set my shift point to 6375 on a stock bottom end without issues.
I was going to go to 6500, but never got around to pulling the governor out to make the switch.
Nice numbers btw, what do you have it in? (if you don't mind me asking
)Quote:
) Its all in my sig.
OK I'm shifting at 6,300 off my shift light so I'm sure it's closer to 6500. My RPMs drop to 5200 when I shift. I filmed me making a few passes on a country road. So I might put a clip on here..
my limiter is at 7200, and im on stock bottom end w/ the stock bolts, youll be fine shifting up there
Quote:
DAMN! I want to know how your got your cam only time! Originally Posted by Demonicbird00
my limiter is at 7200, and im on stock bottom end w/ the stock bolts, youll be fine shifting up there What all is done to your car? if you don't mind me asking.
Quote:
No guts, no glory LMAO. You got a 4-leaf clover pinned to your visor?Originally Posted by Demonicbird00
my limiter is at 7200, and im on stock bottom end w/ the stock bolts, youll be fine shifting up there Quote:
Hell he must have a leprecon in the back of his car Originally Posted by James Montigny
