Enough tire? - and other questions.
I took the advice of you folks who post here frequently and swapped out the Yank SS3600 converter for a PT (4000) series.
Now, I need your advice on how to make it work for me at the track. 1. I've been told the 275/17 MT DR's won't dead hook anymore, but, I'm not at a huge power level and I think they'll still hook with a few suspension adjustments. Do you agree?
2. With the old SS3600, I'd heat the M/T's (17 psi [hot]) and launch at 1800-2000 rpm. With the PT4000, should I now stall it to around 2800-3000 and leave with less foot into the pedal?
3. If my BMR TA is set for -1.5 pinion angle and LCA's are in bottom relo bracket hole, should I set the pinion angle to 2.5 or 3.00 to accomodate the new converter?
4. Which hole should the LCA's be set in the relo brackets for the best hook traction, generally speaking?
Let me know what you think ...
Thanks!
on teh tq arm position and lca - mess with one thing at a time. 1.5 negative of (theoretical) pinion angle is just fine. it really doesnt effect the car as much as most think. lca relocation should be in middle hole if you are not lowered. the lowest hole will just put more load on teh rear tires. sometimes that isnt always a good thing
good luck and enjoy testing.
Derek
2. Something you have to play around with. I always had best luck flashing 4l60e converters.
3. No, the extra stall will offset the decreased STR. It'll prolly hit around the same maybe even harder now. Plus, as Gator mentioned, its not that big of a deal anyways
4. At your power level, you should be able to use the bottom hole.
:Suspension/Chassis:
Heavy Duty Bilstein Shocks (old style, not SLP)
BMR adjustable TA @ -1.5
Front 35mm Strano sway bar
Rear BMR 22mm chromemoly solid bar
BMR Weld-in Sub-Frame Connectors
Lower Control Arms
Panhard Rod
Driveshaft Safety Loop
Relocation Brackets
As for the 275/17 M/T DR's, I did like the M/T website suggested and started at 16 psi and worked my way up to 22 psi. They seem to work best at 17-18 psi with a hard 5-6 second burnout ... at least for me.
PT4000 on 275/40/17 mt drag radials, hal shocks/springs, bmr tq arm, umi lca's and panhard rod, no front sway bar, flashing it would net me 1.58-1.60 dead hook EVERY pass, leaving at 2700rpm dead hooked to a 1.54 60ft. The car had more in it, I was afraid of breaking the driveshaft so never launched any harder. It did pull the front heavy 17's a solid foot also. Also this combination went wheels up quite a few times on the street and left hard.
Keep playing with it until you get it to hook.
Also start with your air pressure higher and work yourself down, not the other way. Get the lca's closest to level without pointing down toward the front. I would get some front shocks for better weight transfer. That along with good tires, you should see 1.5's atleast.
Just gives me morE time to do what I love ... RAAAAAACING!!!!!!!!! I'll post up any gains I see on Friday night. Hopefully, I can get several runs in since a lot of folks will be up at the Gator Nationals ... of course, it's gonna' suck BAD if it's all ricers with no big slick cars so I can run in their groove.
I'll try it off idle and work my way up. Hopefully, I will be able get 3-4 runs in to see how it works leaving from different rpm's, as well. Once I get the 'driver mod' down, I'll start with tires at 20 psi and make individual changes like LCA relo bracket hole location. Once I find the position which works best, I'll start playing with the tire pressure.
Any advice is always welcome ...
I'm going to try with 20 psi tonight in the MT DR's. No air pressure adjustments ... just want to see what rpm level the PT4000 likes off the tree, to see what works best. The lower pressure probably has been costing me about 1 mph ... more concerned about ET/60' times, though.
