Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Camaro and Firebird NHRA Safetly Requirements<br>Important information to help you understand your Camaro or Firebird.
"What do I need for.." Safety Requirements for NHRA (Rollbar, Rollcage, harness, etc)
#42
Ummm..
You may way to fix up the second post in this sticky. Unless I'm missing something completely the following NHRA illustration of a sample roll cage is good to 7.50 NOT 8.50.
![](https://ls1tech.com/forums/attachments/drag-racing-tech/245744d1280674820-what-do-i-need-safety-requirements-nhra-rollbar-rollcage-harness-etc-rollcage.gif)
#47
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
JL you are right on the bottom bar. I had it put on mine for the cert and it wasn't needed on a non-modified floorpan. I'll have to check the NHRA rulebook on it when I get a chance b/c I know it is required for some applications.
#49
Race your car!
Drag radials are no different then slicks. Hell with radials I'd have MORE safety stuff, like better studs, etc.
You go into tire shake, or wheel hop with the radial and believe me it's gonna have just as good of a chance, if not a better chance of doing some carnage.
#51
The title of the illustration clearly states:
FULL-BODIED CARS
7.50 Seconds and slower
Unless my reading comprehension went totally downhill, that means that the illustration shows a rollcage that is NHRA approved for cars going no quicker than 7.50 seconds in the 1/4 mile.
FULL-BODIED CARS
#52
Race your car!
That picture is from an older rulebook. The rule changed in 2007 I do believe, if you want to go faster then 8.50 in the 1/4 you need a 25.5 cert chassis.
sportsman cage (8pt) 9.99-8.50
25.5 8.49-7.50 @ 3600 lbs
25.6 good to 6.50 @ 3600 lbs
25.2 good to 6.0 @ 3200 lbs
25.1 and 25.4, but I don't recall off the top of my head what they're good to, I know that they're for FAST cars, that much I'm sure of.
#53
#54
7 Second Club
1 Post
My apologies; I didn't see the "2007" on the illustration. It was linked by another moderator, and I did have the 9.99 to 8.50 rules listed. Sorry for the confusion!
On the M/T ET Street radial question, they are considered a radial thus a driveshaft loop is not needed until 11.49 and quicker. However as JL pointed out, safety is never a bad thing, and luckily most driveshaft loops for F-bodies are a bolt-it deal (I have a Metco on my Formula that simply bolted in place and although I don't need it it's nice insurance to have).
Derek
Derek
#55
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
25.6 doesn't exist
25.3 is 6.50 @ 3600lb
25.1 is 6.00 @ 2800lb
25.4 is 7.50 @ 3600lb (full tube chassis)
25.5 is 7.50 @ 3600lb (OEM frame/unibody)
#58
7 Second Club
1 Post
Justin, the NHRA rulebook doesn't list an e.t. where a fuel tank must be replaced with a fuel cell.
There is a general rule on both tanks and cells:
"All fuel tanks must be isolated from the driver's compartment by a firewall, completely sealed to prevent any fuel from entering the driver's compartment."
However, if you do replace a tank with a cell, the rulebook states:
"fuel cells must have a metal box protecting the part of the fuel cell that is outside the body lines or trunk floor, excluding hose connection area in rear. Non-metallic fuel cells and tanks must be grounded to frame."
#60
Quick question guys, I'm on my cell otherwise I'd search thru the forums, but it'd take all day on this phone.
- when having the battery mounted upfront "small lightweight battery" is it required to have an on/off switch still reguardless of et or mph?
-on the ds loop, is there a specific location in the tunnel this needs to be or will say the middle between rear and trans?
