a4 with ms3
But i run the Ms3 cam only so ms3 cam, longtubes, 4400 stall, 4.10 gears Ported FAST 90/90 and then all the other boltons... still on stock untouched heads
10.97 at 123 w/a 1.46 sixty foot
100 shot 10.48 at 130.1 with no traction and a 1.57 sixty foot
MS4, ti retainers, dual springs, etc.
stock unported 853 casting heads
LS6 intake, ported TB
stock cube, stock piston/rod/crank ls1
Pacesetter 1 3/4 LT's, ORY, no catback
Coan built TH400 RMVB and transbrake
Yank 5000rpm converter
9" rearend w/ 4.33 gear
BMR adjustable torque arm, mounted to trans crossmember
UMI rod ended LCA's
CE shocks in rear
QA1 up front
Stock K member
Front sway removed
Weight reduction-
No interior
No AC
No p/s
No EGR/AIR pump or hoses
Lift off fiberglass hood
bumper supports
Wheels-
15x10 and 15x3.5 prostars
Rear tires 325/50/15 MT radial and a 28"x11.5 et street.
I too am looking for 10's.
thanx .................."""""""i want to go fast""""""""
