Drag Racing Tech
narrowed 9 inch help
Old Mar 15, 2008 | 05:28 PM
scott94z's Avatar
Default narrowed 9 inch help
just bought a set of 315/60/15 drag radials, does anyone know how much to have the rear end housing narrowed? I have draglites with 7.5" backspacing. And I want the tires to be tucked in the wheel wells with the car car lowered. Also using offset lcas.
Thanks in advance for any info
Old Mar 15, 2008 | 05:29 PM
borninatransam's Avatar
thats big enough to fit a 10" tire back there with that backspacing. i dont see where any narrowing would need to be done.
Old Mar 15, 2008 | 05:39 PM
scott94z's Avatar
I want the car to tuck the tire inside the wheel well, I have 27x10.5's mounted right now, it looks like it won't tuck the drag radial(much wider)
Old Mar 15, 2008 | 11:57 PM
ahh sorry didnt catch that in the first post.
Old Mar 16, 2008 | 09:30 AM
scott94z's Avatar
thats ok, anyone know??
Old Mar 16, 2008 | 11:22 AM
Steve Burger's Avatar
LS1TECH Sponsor
Minitubs done? If not it won't work. YOu will not be able to puul the wheels in far enough to clear.
Old Mar 16, 2008 | 11:35 AM
scott94z's Avatar
I will be mini tubbing
Old Mar 16, 2008 | 11:36 AM
scott94z's Avatar
I know stevemilz narrowed his rear 1.5 per side (315/60/15) with 7.5"BS but its hard to tell exactly how far they are tucked
Old Mar 16, 2008 | 01:40 PM
Jantzer98SS's Avatar
I think thats what you need. 1.5" on each side should put you under the outside like of the fender. If it hits on the inside fender you can do a little chop (don't have to mini-tub) in just that one critical area in the front. That would for sure give you the room.
But my opinion.... if you're going to narrow, atleast go 3" per side and get better backspaced wheels that look better and you save more weight that way.
Scott
Old Mar 16, 2008 | 02:46 PM
scott94z's Avatar
I just wanted to use the wheels I already had, if I can sell them I will buy new ones with a different offset.
