pictures of weight reduction on cdr's cam only car
this is my cam only project car.... 232/234 cam, performabuilt lv2, 4000/2.5 fuddle, 4.10's ect ect...
the pictures are of the front end of the car, sure u recognize the radiator, air lid ect... the front bumper is not finished, but you get the idea. infact none of it is finished, that is just all the **** i initially hacked off the front end. i need to go back and clean everything up and even everything out but just some pics to give you an idea of some of the weight reduction
its getting atleast a 6pt. maybe a 10pt bar for the spray.
wheels skinnies and 28x325 m/t dr's, lightweight carpet maybe... ill post up more pics once everything is finished.
right now without the cage and really no lightweight parts bought the car is around 3000-3050 raceweight, im just hoping i can offset the cage with a lightweight k member/battery and other things...
whats up with the 2 tone front end colors...and i think by cutting the mouth into the catfish of the front end is going to cause more drag than anything...have fun though i know i do with weight reduction...
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
it all else fails get some bondo or something and u can patch those tiny holes
i dont think it will hurt my 1/4 mile times bc of drag.... top speed maybe, i could be wrong though... atleast nothing will overheat
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
OWN3D BY MY PROF!
![](http://img509.imageshack.us/img509/5746/keepdrillingvd9.jpg)
i used a 35$ drill with a tiny pilot bit... just to get the hole started over the spot weld then i used a 3/8th to kinda open it up... the hard part was finding them all. i spent 20 minutes trying to pry the first piece out until i realized there were to more welds i didn't hit lol
Race your car!
I've seen it removed, when you do a minitub it has to go to make clearance. But, does it add any structure to the car? I assume it does, or they wouldn't have bothered putting it there. If it was a good idea to leave out, GM would have to save a dollar in sheet metal I'm sure.
