Drag Racing Tech
5 pt harness question
Old 03-22-2008, 03:09 PM
MetallicaMatt's Avatar
Default 5 pt harness question
I bought a simpson camloc 5 pt, roll bar wrap harness
there aren't any brackets at the end of the points, what are you guys using to connect them to the car?
I've seen the crotch mounts, do I need to get more for the side harnesses?
Old 03-22-2008, 08:55 PM
Jantzer98SS's Avatar
Use an eye-bolt on the front (may need the hook option for the crotch strap), the stock seat belt mounts on the sides, and wrap around for the rollbar.
Old 03-22-2008, 11:44 PM
But what hardware to connect the belts to the sides?
Old 03-23-2008, 09:40 AM
WS6HUMMER's Avatar
Man I think I know what your talking about, I got a set of 5 point cam lock Stroud harnesses and they were like that. I ordered the wraparound type for my wolfe roll bar and they came in without any eyelets at all. Even the crotch straps and lap belts didnt have anything in them to run a bolt through. I called stroud and they got with the place I ordered them from and they ask me to send them back to stroud so they coud add anchor brackets to the lap belts. If you run the Wolfe crotch strap mounts you wont need anything on the crotch strap, leave it wrap around style. Hope this helps.
Old 03-23-2008, 09:54 AM
csjta2's Avatar
You will need to use one of these setups
http://www.jegs.com/i/Simpson/856/31019/10002/-1/745712|10495
Old 03-23-2008, 11:38 AM
Here is what I need I think:
http://store.summitracing.com/partde...5&autoview=sku
BUT it says it is ONLY for 2" wide belts....mine are 3" ?!?!
Old 03-23-2008, 11:40 AM
They aren't Simpson, but I guess these should work
Old 03-23-2008, 02:41 PM
WS6HUMMER's Avatar
Yes that is what you would need, I had to send my belts back for Stroud to sew them in but I dont see why you couldnt just wrap them just like you do to the cross bar on the main hoop.
Here's a link to the Wolfe crotch strap mount, its one less hole you'd have to drill and it looks really clean.
http://www.wolferacecraft.com/detail.aspx?ID=252
Old 03-23-2008, 07:50 PM
Drake's Avatar
I just used the stock seat belt mounting locations for mine.
Last edited by Drake; 03-23-2008 at 07:53 PM. Reason: Disregard, I figured out what you're talking about. Posted too quickly.
Old 03-23-2008, 08:27 PM
WS6HUMMER's Avatar
Yeah, most of us do. His problem is that every end is just a peice of fabric, there's nothing there to put a bolt through.
Old 03-23-2008, 08:44 PM
Drake's Avatar
Yeah, I posted too quickly, then figured out what he was talking about (see the edit)... sorry bout' that.
