Which Lightweight Battery?
Not sure, but I would imagine not very long.
Did I mention this is for a DD? I hope I'm not shooting myself in the foot for getting a pin on hood and a weak battery.
But then again a mod is a mod!
On a side note my VFN pin on was ordered today.
6 week wait!I cant wait to see how she handles once all that front weight is gone!
They told me 6 weeks and it took 10 weeks.
I just want it now! I Keep thinking about it.
BTW I got the regular stock pin on, nothing wild like a cowl, SS or sunco style.
My car is not a sleeper but Id like for it to look like it was stock from the factory. Im more into less is more.
Although the hood pins will be red flags!!
with any small battery, just dont leave anything on or it will kill the battery.
this one comes in around 17lb's and cost half of the odyssey version and you are able to warrenty it out at oreillys
here is some good information
By Brand:
Braille**:
Braille B3121 ----------CCA: 550 ---- weight: 21lb ---------------- CA: 742
Braille B2015 ----------CCA: 425 ---- weight: 15lb ---------------- CA: 574
Braille B14115 ---------CCA: 360 ---- weight: 11lb,8oz ------------ CA: 486
Braille B106 -----------CCA: 210 ---- weight: 6lb,6oz ------------- CA: 283
Westco:
Westco Miata ---------CCA: 475 ---- weight: 25lb
Deka:
Deka ETX30 -----------CCA: 370 ---- weight: 21.7lb
Deka ETX20 -----------CCA: 270 ---- weight: 15.5lb
Deka ETX18 -----------CCA: 300 ---- weight: 18lb
Deka ETX16 -----------CCA: 275 ---- weight: 17lb
Deka ETX14 -----------CCA: 200 ---- weight: 12lb
Deka ETX12 -----------CCA: 180 ---- weight: 9.4lb
Deka ETX9 -----------CCA: 120 ---- weight: 6.3lb
Odyssey:
Odyssey PC680 --------CCA: 220 --- weight: 15lb / 16lb For MJT*
Odyssey PC925/MJT ---CCA: 380 --- weight: 24lb / 26lb For MJT*
Optima:
Optima 34&34R --------CCA 800 -----weight: 37.9lb --------------- CA: 1000
Optima 37/78 ----------CCA 800 ---- weight: 38.8lb --------------- CA: 1000
Optima 75/25 ----------CCA 720 ---- weight: 33.1lb --------------- CA: 910
Optima 25&35 ---------CCA 720 ----- weight: 31.7lb --------------- CA: 910
Duralast:
Duralast 8AMU1R ------CCA: 330 ---- weight: 25lb
Marathon:
Marathon MAR-8AMU1R-CCA: 320 ---- weight: 25lb
By CCA:
Optima 34&34R --------CCA 800 -----weight: 37.9lb -------------- CA: 1000
Optima 37/78 ----------CCA 800 ---- weight: 38.8lb -------------- CA: 1000
Optima 75/25 ----------CCA 720 ---- weight: 33.1lb -------------- CA: 910
Optima 25&35 ---------CCA 720 ----- weight: 31.7lb -------------- CA: 910
Odyssey PC925/MJT ---CCA: 380 ---- weight: 24lb / 26lb For MJT*
Odyssey PC680 --------CCA: 220 ---- weight: 15lb / 16lb For MJT*
By Weight:
More info:
Braile:
Probably Deka rebadged
**no info on website on what Temp the CCA and CA test are done at...
DEKA:
Come with M6 Thread on terminals - you will need adapter to SAE automotive Terminals.
Rebadged as BigCrank, Braille and other brands // BigCrank has cheap price .
(Proved and discussed on the vwvortex there is a whole thread about it.)
Odyssey:
*MJT: Metal Jacket + Terminals.
Also the Odysseys have battery mounting brakets avaible.
Miata Battery:
Duralast rates them at 330CCA, Marathon at 320CCA, Westco at 475CCA,
make what you want of this info but personally I'm not getting a Westco Battery
Made by EastPenn Mfg.
Sold under:
Marathon MAR-8AMU1R (1Year Warranty)
Westco 12V31M (4 Year Warranty)
Duralast 8AMU1R (8Year Warranty - apparently WAS avaible at autozone)
I couldnt find the terminal adapters for those little batteries so I just used the supplied screws.
It cranked the car fine, but............ big but.
Since the terminals are so small i guess they werent making enough contact and it got hot.
Nonetheless the battery crapped out when the fans kicked on, the A/C would do the same.
I thought bout it twice. Having an undependable setup for a DD.
I took it back. 10lbs was not worth being stranded somewhere.
On a side note my hood was delivered from VFN in 2 weeks.YES!!!!!!!!!
Its already installed, however no Pics until its all painted.
Im getting my front bumper cover painted too, and want to polish the headlights.
I will get you guys pics soon.
ANy of you know where to get some nice stainless steel rings? The pin kit I bought had some super cheap thin ones, they look like they will rust. I want some stainless steel ones.
By Brand:
Braille**:
Westco:
Deka:
Odyssey:
Optima:
Duralast:
Marathon:
By CCA:
By Weight:
More info:
Braile:
DEKA:
Odyssey:
Miata Battery:
Sold under:
Bump,
Great thread.. Sticky worthy IMHO!
You kill the battery if you leave something on like the radio, fans, etc.
The threads are metric threads. I just use some extra coil pack bolts with a few washers to space the cable cover away so it doesnt bind up next to the battery. It makes since once you bolt it up.
75-DLG is the # stamped on it
http://www.autozone.com/R,3322484/ve...ductDetail.htm
45 lbs - My Battery (1000/850 cranking amps!! LOL)
12 lbs - Battery Relocation Box (Plastic), and cables
16 lbs - 16 lbs Battery from Walmart
41 lbs REMOVED!!!
This mod wil go nice along with my HVAC delete (30+ lbs), carpet removal (30+ lbs), VFN Sunoco Pin On Hood (30+ lbs), lightweight front runners (20.2 lbs), rear bumper removal (22 lbs), etc. I will have a thread up soon with all of my progress!
