Drag Racing Tech
SLP Linelock Leaking
Old May 22, 2008 | 08:39 PM
rmata's Avatar
Default SLP Linelock Leaking
Has anybody had any problems with their SLP linelock? I've had mine for probably like 3yrs and I noticed my solenoid was leaking. Looks like the solenoid is two pieces and all around the seal in the middle is where the break fluid is coming out from. My breaks feel terrible now so I guess I better get this fixed asap. Is there like a rebuild kit or something, or should I just buy a new solenoid?
Old May 23, 2008 | 09:08 AM
ToxicFormula's Avatar
try tightening the nut type thing on top of the solenoid. It may look like its tac welded on there but its not...or atleast mine wasnt and when I tightened it, it fixed my problem
Old May 23, 2008 | 01:34 PM
TwoFast4Lv's Avatar
We have replaced three failed SLP units in cars.
Old May 23, 2008 | 01:50 PM
01sscam's Avatar
Man-Crush Warning
My solenoid took a **** after about six months. Replace it with the sjm kit.
Old May 23, 2008 | 03:45 PM
rmata's Avatar
Yeah, I think that's what I'm gonna do. My ABS doens't work anyway so I might as well shed a few pounds while I'm at it.
Old May 24, 2008 | 03:32 PM
1BADAIR's Avatar
mine leaked when the nut came loose. tighten it and you should be good
Old May 24, 2008 | 10:04 PM
rmata's Avatar
I think you're not getting what I was trying to say. My solenoid is not leaking from the nut. It's leaking from the middle. Here's a picture to show you what I'm talking about.
Old May 25, 2008 | 12:12 AM
1BADAIR's Avatar
there is a thin nut on the top. The nut hold the solenoid/magnet together.
try rotating the top piece(part with the mount) separately from the part below the area you circled. It should not turn
