Drag Racing Tech
Another SUX2BU Setup
Old May 22, 2008 | 09:42 PM
bad2000z's Avatar
Thumbs up Another SUX2BU Setup
My buddy and myself put together a ram air setup for my car a few weeks ago. He did 90% of the work, so I snapped some pics along the way.
-We used 6" to 4" rubber couplers from Lowes instead of tin reducers.
-We used neoprene brake duct hose from Jegs instead of crappy dryer hose.
-We used two 4" exhaust tubes tack welded and urethane sealed to a metal plate fitted to the bottom of the stock air filter holder.
I think it turned out really nice. I won't have any real before and after results because I made a **** load of changes to my car over the winter (9", BMR Drag Bar, Draglites). What I can tell you is the car is just as quick at my local 1/8 mile track as it was last year, even with the extra weight from the 9" and the big sway bar. My best ever time there was 7.19 (it's a slow track), two weeks ago it went 7.20 with the new setup. I think maybe the ram air setup offset the extra weight/drivetrain losses with the new rear.
Old May 22, 2008 | 10:34 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Looks good to me. Do you have any pictures from the front?
Old May 22, 2008 | 11:10 PM
RAGENZ28's Avatar
Pretty cool...
Old May 22, 2008 | 11:20 PM
cookba's Avatar
oh cool, ya lets see more pics. what was the total cost for all this? bet its chaeper than a SSRA or FTRA
Old May 23, 2008 | 03:41 AM
tektrans's Avatar
Yeah man, looks great!!
Old May 23, 2008 | 07:44 AM
bad2000z's Avatar
We split the cost of the neoprene hose (there's plenty to do two cars), so it ended up costing me about $75.
Old May 23, 2008 | 07:46 AM
bad2000z's Avatar
I think I do have a couple pics from the front, I'll check when I get home from work tonight.
Old May 23, 2008 | 09:03 AM
Lickeyman's Avatar
Hell yeah i like the rubber couplers big time
Old May 23, 2008 | 04:09 PM
chrs1313's Avatar
where did you get the hose from...
Old May 23, 2008 | 04:32 PM
94 guy's Avatar
is there a way to do this with the a/c condenser? and do you have pics of under the air box?
Old May 23, 2008 | 05:02 PM
OWN3D BY MY PROF!
You can do it with the condensor in there. You're just going to have to squish the hose.
Old May 23, 2008 | 05:24 PM
heymoej's Avatar
looks clean.........................nice job...............
Old May 23, 2008 | 10:22 PM
bad2000z's Avatar
The hose came from Jegs. 4"x11' $69.99
http://www.jegs.com/p/JEGS/760977/10002/-1/82467
Old May 24, 2008 | 11:40 AM
studderin's Avatar
looks good seth.
I used some 4inch black duct from mcmaste carr, had like a .030 wire. Was a little cheaper. like $5 a ft I belive.
Old Aug 28, 2008 | 03:00 AM
Fast 95 Z28's Avatar
how did u keep the rubber couplers attached to the front bumper? i dont see any screws. did you just wedge it over the hump and it stays on while driving? and how does this setup do in the rain?
Old Sep 27, 2008 | 11:34 PM
silverz28camaro's Avatar
Man, I am diggin this setup. My car does have a problem with top end with the 3.73 gear and 3600 stall being loose at the end of the track. My trap rpm is around 6300-6400. If i can gain top end and mph from a simple $100 mod, I'm all for it.
Old Sep 29, 2008 | 11:08 PM
eric01ss's Avatar
can we get pics from the front and maybe a write up on this!!
Old Oct 4, 2008 | 02:49 PM
studderin's Avatar
some of mine
Old Oct 4, 2008 | 04:44 PM
2002_Z28_Six_Speed's Avatar
you should get some kind of wind speed sensor and get it rigged up in there to see what kind of flow rate you are actually pulling through there.
Old Oct 6, 2008 | 12:13 AM
Magnus's Avatar
LS1TECH Sponsor
No need for a wind speed sensor, you can just use the PCM's MAP sensor to see if you're actually seeing increased manifold pressure.
