Drag Racing Tech
Car Hauler - Securing Car to Trailer??
Old 06-21-2008, 10:00 AM
tee-boy's Avatar
Default Car Hauler - Securing Car to Trailer??
How are u folks strapping your cars down to car hauler? I figure 2 straps around the axle tube for the rear and one or two up front. Don't know what to secure straps to on car for the front.
Old 06-21-2008, 10:03 AM
LS1TECH Sponsor
Steve Burger's Avatar
I use the factory tie down points. They are behind the A Arms on the frame.
Old 06-21-2008, 10:06 AM
silverbeast's Avatar
^^^^ What he said. Its much easier that way.
Old 06-21-2008, 10:09 AM
tee-boy's Avatar
thanks. never noticed those. what about the rear? You going around the axle tubes?
Old 06-21-2008, 10:26 AM
csjta2's Avatar
I go around the outside of the front control arm (aftermarket control arms)
For the rear I go around the axle tube
I use Mac Tiedowns
Old 06-21-2008, 03:54 PM
camscam02's Avatar
We go around the each A arm on the front and use only one on the rear axle tube down to the middle of the rear of the trailer. car hasnt gone anywhere
Old 06-21-2008, 04:08 PM
LS1TECH Sponsor
For the rear I have tie downs built into the rear.
Old 06-21-2008, 04:09 PM
SpaZMaN's Avatar
Font A arms, then around the axle housing in the back
Old 06-21-2008, 10:31 PM
Black Sunshine/ 00SS's Avatar
You could get some wheel straps, that go around the wheel & hook to the trailer. This is the method that toyota & nissan are requiring on all the cars that we haul on our car haulers. They hold just fine, on the cars & also on the big Titans.
Old 06-22-2008, 09:24 AM
Old Geezer's Avatar
Always a good idea to "X" the tie downs, both ft and rear. That keeps the car centered on the trlr, should you have to swerve, to avoid??, or in a panic stop, where the tow vehicle and trlr jacknife..
We always tie to the chassis, in order to minimize swaying. Remember, the c of g is pretty high.
Old 06-22-2008, 11:15 AM
Race your car!
JL ws-6's Avatar
I X the rear straps, loop them around the rear and tie them to the trailer, the front I use the tie down holes on the chassis.
I will add a set of tie down hooks on the front of the chassis if I ever remember to have my fab guy do it while the car is there for something else, just to make things easier.
I was thinking a set of hooks/tabs welded to the chassis up in the front, to decrease the strap lenth and for the ease of things.
Someday when I have a real trailer with a winch in it, I'll probably just attach the winch to the front of the car, and a set of straps to the trailer, hook on the back of the car and drag it in with the winch, and let the winch be the front holddown.
Old 06-22-2008, 12:39 PM
6 & 8 Second Club
mrdragster1970's Avatar
Please, everyone, not just JL. DO NOT use the winch as a strap. 2 in front, 2 in back.
The winch is not a strap, & it's not save to use it as such.
Old 06-22-2008, 01:48 PM
Old Geezer's Avatar
Exclamation Absolutely!!
The winch mfgrs warn AGAINST that very practice. If the winch clutch fails, the guy behind you is pfhucked!!!
Old 06-22-2008, 03:26 PM
Race your car!
JL ws-6's Avatar
I wasn't aware of this.
Scratch the winch idea.
Old 06-22-2008, 08:07 PM
FASTFATBOY's Avatar
I have stock front lower control arms in the front, I put my strap hook in the hole in the bottom of the lower control arm.
On the rear I "x" the straps and I made these to hook to. They are high quality "I" bolts that I had welded closed so they cant pull open. Has a nut on both sides of the LCA relocation bracket.
[IMG][/IMG]
Old 06-22-2008, 09:08 PM
CamaroRacing12's Avatar
hahaha JL
Old 06-22-2008, 09:54 PM
tee-boy's Avatar
good info. what size straps are you using? I think 800 lb working load is what rating straps I currently have. I figure (fuzzy math) that adds to 1600 lbs for front and same for back w/ 2 straps on each end.
3500 lb car times tow vehicle velocity squared comes out to a lot more than 1600 lbs. Might need to go w/ bigger straps. Last think I need is my car with me in my pickup cab.
Old 06-23-2008, 04:36 AM
Race your car!
JL ws-6's Avatar
The straps I use are I think a 6000 lb load strap. You have to think about the force that the strap will see if soemthing bad happens and the car tries to fly off the trailer, not just the weight of the car.
I bought mine @ walmart, they were way too long so I had to cut them back some, the strap material is 3 inches wide.
Old 06-23-2008, 12:09 PM
Tireburnin's Avatar
You all should really buy quality straps. If you get into a real accident it could be life or death. Most cars (ours) need 10K lb breaking strength straps which are roughly 3K lb working. Here is some info from a strap manufacturers website.
Important Information:
A 4 Point Tie-Down System is Recommended for use on ALL 4 Wheeled Vehicles.
3500 lb Rated (E Track) Systems-Recommended for use on Vehicles weighing 2100 lbs or less.
5000 lb Rated (Flat Snap) Systems-Recommended for use on Vehicles weighing 3300 lbs or less.
6600 lb Rated (Twist Snap) Systems-Recommended for use on Vehicles weighing 4000 lbs or less.
10,000 lb Rated (Twist Snap) Systems-Recommended for use on Vehicles weighing more than 4000 lbs
The minimum Tie-Down Restraint applied to the front end of a vehicle and the rear end of a vehicle should be equal to or greater than 3.3 times the gross weight of the vehicle. Application of the 3.3 factor is for the purpose of establishing the Minimum Load Restraint Requirement to safety secure a "Rolling Dynamatic Load" as represented by the Gross weight of the vehicle in an emergency situation.
Old 06-23-2008, 12:18 PM
Race your car!
JL ws-6's Avatar
6600, that's what the ones I have are rated to. 2 of them per end of the car should be enough to support a 3050 lb car without a problem.
Quick Reply: Car Hauler - Securing Car to Trailer??
