Drag Racing Tech
LCA Relocation Brackets
Old Jul 10, 2008 | 11:38 PM
358chevycamaro's Avatar
Default LCA Relocation Brackets
So I am getting ready to buy some and wanted to know what kind of results you all have netted from just installing these and what hole you have them in. Thanks in advance!
Old Jul 10, 2008 | 11:51 PM
waterbug1999's Avatar
Yoy really dont gain any ET.. but, it prevents wheel hop. So, I guess if you can eliminate wheel hop, that might help your ET I suppose.
It applys even more for lowered cars.. I had mine on the last hole.
Old Jul 11, 2008 | 12:05 AM
Well I hook fine out of the hole but my best 60' was a 1.64 running 7.20's but I only have non-adj Sphoon LCA's, non-adj Panhard rod, and subframe connectors. I just installed Drag Bags because the rear was squatting too much, but I haven't got to see if I can beat my best 60' yet, I just want to know if it will help out my pitiful 60'.
Old Jul 11, 2008 | 12:12 AM
Fast_94_Z's Avatar
i have a set of umi weld ins for sale brand new pm me if your interested.
Old Jul 11, 2008 | 11:34 AM
RAGENZ28's Avatar
Of course you'd reduce your ET, any time you get a car dialed in closer to your ideal "Instant Center" location your car is going to 60ft harder which equates into a quicker 1/4 mile time. If you do get relocation brackets try both sets of holes and readjust the pinion.
Main problem is people buy adjustable parts and are afraid to adjust them because they find a setting that works, but if you want the most out of it you're going to have to try a lot of settings until you get your optimum setup.
Old Jul 11, 2008 | 04:08 PM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
We offer a bolt on and a weld on version. Try both sets of holes but it seems that the bottom hole works the best. If you have any questions please give me a call.
http://www.bmrfabrication.com/F-bodyDrivetrain.htm
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Jul 11, 2008 | 04:48 PM
BAKED's Avatar
Spray that bitch outta the hole. I guarentee your 60' will be better.
Old Jul 11, 2008 | 05:19 PM
Hell yea!!
X2!
Old Jul 14, 2008 | 08:35 AM
UMI Performance's Avatar
The lower control arm relocation brackets are one of the most inexpensive traction devises you can add to your vehicle. While every vehicle varies we usually recommend to set them on the lowest hole and go from there.
If you have any additional questions please ask and I will be glad to help. We also offer a bolt on and weld in design seen below.
www.umiperformance.com/2010
www.umiperformance.com/2012
Thank you!
Ryan
Old Jul 14, 2008 | 12:01 PM
Matt D's Avatar
Retired Street Racer
I had the UMI bolt-in ones in the bottom hole, on my bolton car, and went the times in my signature.
Old Jul 25, 2008 | 12:30 PM
Car is running good Matt
